ABS light. - Mustang Evolution
Old 08-01-2013, 05:05 PM   #1
03fastblack's Avatar
ABS light.
I am running a bigger radius tire on the back than the front. Will that trigger the and light?
03fastblack is offline   Reply With Quote
Old 08-01-2013, 05:14 PM   #2
Venomouz831's Avatar
No
)02 Gt, Founder of WE2G
Old 08-01-2013, 06:09 PM   #3
Slow4V's Avatar
May affect speedo .. That's it though
Old 08-01-2013, 06:10 PM   #4
Hmm right after I put these tires on it came on.
Old 08-01-2013, 06:13 PM   #5
Slow4V's Avatar
It's possible they tore one of your abs wires.. Accidentally like most dumbass tire guys do..
I've seen it happen ,
Only way to find out is to take off each wheel and check the wire behinde hub
Old 08-01-2013, 06:34 PM   #6
I did some reading. Having a bigger diameter on the back throws the abs code.
Old 08-01-2013, 06:43 PM   #7
Slow4V's Avatar
NA , I'm running 295-35-18 .. No code ..
I've ran 315/35/17s .. No code
Also 325/50/15s lol no code.
18x10
17x9
15x10.5
Old 08-01-2013, 07:46 PM   #8
I'm running 275/35-18 on 18x9 on front and 315/40-18 18x10. Idk fu*k it
Old 08-01-2013, 07:59 PM   #9
Billymich's Avatar
It will throw off your ABS which technically should be altered for every tire/wheel change made (reason race cars don't use ABS) It will sense that your front and rear tires are rotating at different speeds (which is fundamental for ABS function). It shouldn't strongly effect braking, worst case you are leaving some grip on the table under perfect storm conditions ( you won't under perform from a factory ABS perspective.) It's like getting a CAI and not retuning... kinda
Old 08-01-2013, 08:16 PM   #10
Will it hurt anything eventually? I'm going to go back to the right size again
Old 08-01-2013, 08:20 PM   #11
Hasn't come on for me and I just went from 17x8 all around to 18x9/10 this week.
Old 08-01-2013, 08:21 PM   #12
That's not what we're saying. I have 18s all around and running a thicker tire in the rear
Old 08-01-2013, 08:23 PM   #13
Billymich's Avatar
I don't think so. At least my logic would say no, but ABS is complicated.
Old 08-01-2013, 08:29 PM   #14
Thanks man.
Old 08-02-2013, 01:41 AM   #15
I am too lol. Hence why I said 18x9/10, I have 18x9s with 275 tire in the front and an 18x10 with a 285 tire in the rear.
Old 08-02-2013, 09:02 AM   #16
Ya what's your sidewall numbers for your front and back?
Old 08-02-2013, 09:22 AM   #17
1lowGT's Avatar
Fastblack is running a way taller tire in the back than yours
Old 08-02-2013, 11:32 AM   #18
I ran before a 30 tall in the front and a 45 tall in the back and it was fine
Old 08-02-2013, 11:35 AM   #19
1lowGT's Avatar
On your Fr's?
Old 08-02-2013, 04:27 PM   #20
Yea
Old 08-02-2013, 04:39 PM   #21
The light is off now.
Old 08-07-2013, 04:21 PM   #22
Calandro's Avatar
Your light may not even be from tires at all. The ABS system requires high voltage. So if your alternator or any part of your electrical system is starting to ware out one of the first things to light up would be ABS (due to low voltage)
Just a thought about something you want to test.
Also keep an eye on your battery light, and if you have subs in your car, see if your subs shut off at the same as your ABS light comes on.
---------- Post added at 06:21 PM ---------- Previous post was at 06:20 PM ----------
Just a thought. Hope it helps!
Calandro is offline   Reply With Quote
Old 08-07-2013, 05:34 PM   #23
1lowGT's Avatar
Oh hell he's got an old worn out battery too
Old 08-07-2013, 06:17 PM   #24
Yep thank you. I do have a 7 yr old battery
Old 08-07-2013, 08:17 PM   #25
Calandro's Avatar
No problem. A local advanced auto parts can check your battery for free.
02:29 PM
