Disconnected Battery now runs rough - Mustang Evolution
Old 08-01-2013, 07:03 PM   #1
bradh2414's Avatar
I installed a new cold air intake this afternoon, and everything was fine. Then i got a check engine light, and i read that if you disconnect the negative cable from the battery for like 30 minutes, it resets everything. So i did that and when i reconnected the battery and took her for a spin, every time i hit the gas, she would run real rough for a second then would roughly start driving. Any ideas what happened?
bradh2414 is offline   Reply With Quote
Old 08-01-2013, 07:16 PM   #2
Billymich's Avatar
You may need a tune. Disconnecting the battery resets all of the learned stuff in your ECU memory, so it relearns idle and fuel curves based on your driving and ambient conditions.
Old 08-01-2013, 07:17 PM   #3
twotone01's Avatar
Might have some carbon build up or something that the fuel trims have adapted to and when your reset everything, it thinks that it's a new engine.
But I could be wrong. That's what I learned in school haha
twotone01 is offline   Reply With Quote
Old 08-01-2013, 07:17 PM   #4
bradh2414's Avatar
So how long will it do the sputtering/rough driving?
Old 08-01-2013, 07:17 PM   #5
Ubnbit's Avatar
^ well said.
How long did u drive it?
Old 08-01-2013, 07:21 PM   #6
bradh2414's Avatar
just out and around the block. its really loud, and i couldnt control how smooth it ran so i didnt wanna wake up all my neighbors
Old 08-01-2013, 07:24 PM   #7
Billymich's Avatar
Ok, so you're going to want to idle for like 2 minutes with no lights, radio or ac. Then 2 minutes with ac blasting and radio on. Also drive around for like 30 min, some normal driving and some pedal to the metal driving. That might help
Old 08-01-2013, 07:31 PM   #8
bradh2414's Avatar
okay ill give it a try. i just wasnt sure if something went wrong or if the ecu needed to reboot or whatever
Old 08-01-2013, 07:34 PM   #9
Ubnbit's Avatar
It'll take ur car a while to adjust brother as long as there are no other issues going on. My brothers in here are dead on it. Great help guys. That's why I love this forum.
Old 08-01-2013, 07:40 PM   #10
bradh2414's Avatar
thanks everyone. this is why this site is awesome. i posted the same thing on allfordmustangs and didnt get a response. you guys already solved my problem haha
12:39 PM
