my next mod to help reach 12s. need opinions! - Mustang Evolution
Old 08-01-2013, 11:30 PM   #1
98GTCONV's Avatar
Ok so im torn between my next mod. Just did the full pi swap. Im consistently in the mid 13s. I want a little extra kick to help reach 12s.
Soooo...comp 270s? Or nitrous? Or another wallet friendly option?
I have upgraded trick flow valve springs/retainers. Will the 270s work with them?
98GTCONV is offline   Reply With Quote
Old 08-01-2013, 11:40 PM   #2
Nitrous would be the easiest way, but its not power all the time. If i was you i would go with the cams. If your hitting 13s then with a good set of cams and a really good tune you may be able to touch 12s. What is your 60'?
Old 08-01-2013, 11:52 PM   #3
98GTCONV's Avatar
Im on 305 dr's so it varies most of the time under 2
Old 08-02-2013, 12:06 AM   #4
Get the cams, and try to get under a 1.7 60' and you will be in 12s for sure.
Old 08-02-2013, 12:08 AM   #5
98GTCONV's Avatar
Alright will do. Think my valve springs will be ok to use?
Old 08-02-2013, 01:39 AM   #6
Probably want new ones.
Old 08-02-2013, 07:04 AM   #7
Slow4V's Avatar
What's your suspension mods ? Any drag radials ?
Old 08-02-2013, 09:37 AM   #8
98GTCONV's Avatar
H&r ss springs and billstein shocks. 305/30/18 Kumho drs
Old 08-02-2013, 09:52 AM   #9
1lowGT's Avatar
Gears? I would say nitrous too hit a 125 shot, but that wont help unless you're hooking. What tires nittos?
Old 08-02-2013, 09:53 AM   #10
2300turboford's Avatar
If u still have ur non pi pistons u can only run 262 cams
Old 08-02-2013, 11:00 AM   #11
98GTCONV's Avatar
Why only 262s? I have Kumho tires and 4.10 gears
Old 08-02-2013, 11:25 AM   #12
1lowGT's Avatar
Which ones? They radials?
Old 08-02-2013, 11:26 AM   #13
Bc the 270s will hit the pistons they were designed for the pi pistons
Old 08-02-2013, 11:28 AM   #14
98GTCONV's Avatar
Drag radials.
Old 08-03-2013, 12:20 AM   #15
1lowGT's Avatar
They hook good?
Old 08-03-2013, 11:51 AM   #16
98GTCONV's Avatar
Very good.
Old 08-03-2013, 07:00 PM   #17
02GtRespect's Avatar
When you say full pi swap did you swap block? Because non pi block with pi heads holds better compression than full pi. I believe full pi is 9.1.1 and non pi with pi heads is 11.1.1
02GtRespect is offline   Reply With Quote
Old 08-03-2013, 07:02 PM   #18
98GTCONV's Avatar
Npi block still
Old 08-03-2013, 07:13 PM   #19
Id say 100 shot of nitrous from zex they have a setup that it stays on but only sprays during wot. I dont know if any other brand has them. Just what I would go with. Also some mild cams.
Old 08-03-2013, 07:15 PM   #20
98GTCONV's Avatar
Im getting a killer deal on a nx wet kit. 100 shot will be safe?
Old 08-03-2013, 07:20 PM   #21
Should be fine buddy of mine has an 03 gt with 150 shot but his has a tune which I would highly suggest getting done
Old 08-03-2013, 10:39 PM   #22
It puts it at 10:5:1 unless you grind off the intake shroud a d it puts it at like 10:1:1
---------- Post added at 12:39 AM ---------- Previous post was at 12:38 AM ----------
Non pi block with pi heads puts it at 10:5:1
Old 08-04-2013, 02:41 PM   #23
Oh ok couldnt remember exactly
12:43 AM
