Gear ratio - Mustang Evolution
Old 08-02-2013, 02:49 PM   #1
Califas gt's Avatar
Gear ratio
How is it going guys? I'm not sure what gear ratio should I put in my mustang gt 2003? What ratio do you guys recommend? I have stage 1 clutch, flow master, intake, and under drive pulleys. Any suggestions?
Califas gt is offline   Reply With Quote
Old 08-02-2013, 02:50 PM   #2
MidnightBlueGT's Avatar
Manual 3.73 auto 4.10
Try to get a tuner too so you can input the proper gear ratio and keep the odometer and speedo accurate
Old 08-02-2013, 02:59 PM   #3
Califas gt's Avatar
Do I have to get a tuner too? It's not going to be same if I just put the gear? What I'm trying to do is upgrade little by little because the big bucks
Old 08-02-2013, 03:01 PM   #4
No but the new gear ratio will offset your speedometer and make your mileage be inaccurate. There are other ways but for the $ getting a tuner is worth it but no you dont need one if your fine with it.
Id go tuner first then buy gears after
Old 08-02-2013, 03:12 PM   #5
Califas gt's Avatar
Ok any recommendation for a tuner? What other upgrades do you recommend?
Old 08-02-2013, 03:16 PM   #6
Midpipe if you only have a catback, subframes other suspension work. Check the bolt ons sticky and choose which ones you would like to do.
And go with am's sct bama tuner. Mines on the way.
Old 08-02-2013, 07:12 PM   #7
GreenBean 1809's Avatar
+1 my speedo was WAY off after I had my 4.10s installed. Tuner brought it all together, worth getting before gears. I do alot of highway driving and my 4.10s do just fine on the highway. Personal preference, but I dont think i would have been satisfied with 3.73, but no plans on FI for me.
GreenBean 1809 is offline   Reply With Quote
05:02 AM
