Weird Noise coming from engine bay - Mustang Evolution
Old 08-04-2013, 01:29 PM   #1
Vmcgrath's Avatar
I got a 98 mustang gt auto has a noise coming from engine bay almost sounds like a air horn going off but it doesn't it while in part but when I'm driving down the high way my car will not get up and go it just takes it time and it also jerks
Only mods are CIA and full exhaust
And my exhaust sounds like it farting
I just had a problem with my spark plug blowing out had it rethread but the guy put in one motor craft plug and the rest are bosh platinum plugs
Also had to replace a vacuum hose due to dry rotting
Here a video
http://youtu.be/_mLWdVVgW9o
Vmcgrath is offline   Reply With Quote
Old 08-04-2013, 03:00 PM   #2
Vmcgrath's Avatar
Anybody... Help?
Old 08-04-2013, 04:02 PM   #3
Vmcgrath's Avatar
Bump
Old 08-04-2013, 06:33 PM   #4
Doe_Rae_mi's Avatar
Originally Posted by Vmcgrath
I got a 98 mustang gt auto has a noise coming from engine bay almost sounds like a blow horn going off but it doesn't it while in part but when I'm driving down the high way my car will not get up and go it just takes it time and it also jerks
Here a video
I swear I'm not trying to be funny or a smart *** or a dick or anything.but are u blowing a air horn behind the camera?? It sounds exactly like one
Old 08-04-2013, 06:37 PM   #5
Vmcgrath's Avatar
Nope I pinky swear that the noise I'm trying to figure out it coming from my engine bay sound near the throttle body but I can't pin point it
Old 08-04-2013, 06:43 PM   #6
v8pony's Avatar
Sounds like the iac to me...how's your idle?
2002 5spd GT
Feb 2013 Mustang of the Month
Old 08-04-2013, 06:47 PM   #7
Doe_Rae_mi's Avatar
Well it may have something to do with air since it sounds like a air horn? I'm not very good with stuff like that lol. Good luck man
Old 08-04-2013, 06:49 PM   #8
Vmcgrath's Avatar
Thank you for giving me something to look into but the idle stutters and the rpm are jumpy it start up at one the goes down then up and down
Old 08-04-2013, 07:29 PM   #9
Could be a vacuum leak from one of the hoses or the manifold
Mgsgreystang is offline   Reply With Quote
Old 08-04-2013, 07:33 PM   #10
Mfore33's Avatar
Could be a hose that is weak that collapses under load causing the noise. Press on all air hoses to look for weak spongy ones
Old 08-04-2013, 08:04 PM   #11
v8pony's Avatar
Again sounds like an iac problem too me...my buddy tells me he had a similar noise(I never heard it), but changed his iac valve and noise has yet to return.
2002 5spd GT
Old 08-04-2013, 08:16 PM   #12
Vmcgrath's Avatar
Okay I will do that sometime this week thanks for the advice
---------- Post added at 09:15 PM ---------- Previous post was at 09:12 PM ----------
Thank you I will check that out as well
---------- Post added at 09:16 PM ---------- Previous post was at 09:15 PM ----------
I just replace one hose because it was bad it like when ones bad then the all go bad
12:39 PM
