What's my next step??? - Mustang Evolution
Old 08-06-2013, 06:15 PM   #1
67mustang97's Avatar
Region: Vermont
I'm out of ideas I have a cylinder 6 misfire that I can't figure out. Here's what's going on. New engine started up with got 2 codes misfire on start up and number 6 cylinder misfire. I replaced the plugs and swapped the coils around cleared the code still came back with the same codes. Next I swapped the number 5 injector with the number six injector and still got the same codes. Car is tuned what's my next step?
Old 08-06-2013, 08:29 PM   #2
Mfore33's Avatar
You said new engine? Maybe a head gasket leak or problem with valves. Possibly a wire issue
Old 08-06-2013, 08:49 PM   #3
Region: Vermont
If I gave it a compression test that should tell me if it's a bad valve or head gasket right?
Old 08-06-2013, 11:34 PM   #4
Mfore33's Avatar
It should
Old 08-07-2013, 05:05 AM   #5
calebnaasko's Avatar
Could be head gasket. I had the same problem on my 2000 GT. Compression test was fine and it had a misfire on cyl 5. It also didn't have white smoke out of the exhaust. But it ran very rough. Sold it
calebnaasko is offline   Reply With Quote
04:31 AM
