Limited Slip Diff or Posi? - Mustang Evolution
Old 08-08-2013, 12:06 AM   #1
Gobabygo67's Avatar
I'm rebuilding my rear end soon and I wanted to know if I should just continue with having the limited slip differential that came with the car or should i go Posi? Just want a few opinions and experiences if you guys have any
Gobabygo67 is offline   Reply With Quote
Old 08-08-2013, 04:07 AM   #2
Sbales88's Avatar
If you drive it all the time i wouldnt go posi. It wont slip on corners like limited would. But if you dont take a lot of corners go posi
Sbales88 is offline   Reply With Quote
Old 08-08-2013, 06:06 AM   #3
Ish416's Avatar
Posi and limited slip are the same exact thing. Positraction or positive traction was a name GM gave their limited slip differential.
If you want the tires to always spin at the same speed, you will need a spool. I would not recommend a spool for anything but a track car as it will seriously screw up the handling of the car.
Old 08-08-2013, 06:11 AM   #4
Slow4V's Avatar
We don't have posi we have trac lok
01:32 AM
