Exhaust leak and bad TOB? - Mustang Evolution
Old 08-08-2013, 09:14 PM   #1
GreenBean 1809's Avatar
My car has been running rough and lacking pizzazz the last few days. I have noticed a increase in heat in my dash area, a sputtering exhaust note at times, less acceleration at WOT and sounds like my exhaust is quieter and coming from further up. Are these signs of an exhaust leak? How would I narrow the location down? Also noticed a whirling sound and rattle that goes away when my clutch is depressed. Used the search function and seems to be a bad TOB from what i gathered. Not sure what my next action should be.
GreenBean 1809 is offline   Reply With Quote
Old 08-08-2013, 09:17 PM   #2
1996mustang's Avatar
Any cel on? Check engine light. What was the last thing done to the car and how long ago has it been goin on?
Old 08-08-2013, 09:23 PM   #3
No cel. Have been suspecting TOB for 6 months, just been putting it off. Nothing has been done to the transmission only thing to the exhaust has been cat back exhaust. Seems to be an expensive fix to replace TOB. Will this escalate to other problem.
---------- Post added at 08:23 PM ---------- Previous post was at 08:22 PM ----------
Notice exhaust problem 3 days ago, almost felt something "give" while driving. Car runs and operates fine in every other aspect.
Old 08-08-2013, 09:26 PM   #4
Exhaust was put in 3 days ago as well?
Old 08-08-2013, 09:28 PM   #5
No exhaust has been put on and running fine for 4 months. Mid pipe is pretty rusty. Bad cat or gasket maybe?
Old 08-08-2013, 09:28 PM   #6
If you get more heat feeling fron the dash area i would check on the flanges from the cat back. Maybe it came loose or someplace further up. Have the car jacked up, supported and idle the car to see if u can pinpoint it. As well as have someone rev it little by little to find a exhaust leak just in case
Old 08-08-2013, 09:41 PM   #7
Sounds like a PITA. Could be flanges, bolts were rusted, could have come lose. Hope its that easy of a fix.
Old 08-08-2013, 10:00 PM   #8
It could be mine had a rattle and heat from the floor board. My x pipe lost a bolt had to replace it and it felt like she was running poorly
Old 08-09-2013, 04:58 PM   #9
How much for TOB replacement?
Old 08-09-2013, 07:18 PM   #10
The part is $15. Labor is a few hundred...
Old 08-11-2013, 03:37 PM   #11
Concluded that the problem is a bad cat. Gives me an excuse to get a new midpipe
Old 08-12-2013, 10:37 AM   #12
Anyone know where i can get exhaust hardware. 8 bolts all together, or at least the specs. Also 2 gaskets are needed for mid pipe install correct?
Old 08-25-2013, 10:16 AM   #13
04sonicbgt's Avatar
Don't mean to thread jack, but I recently was rushed over a speed bump by the a**hole behind me and I pretty much destroyed a cat, and cracked a muffler, leaving me with a gnarly exhaust leakage :bang head: . So this leads me to ask, should I just go catless, or replace the cats. I don't have to pass emissions, so no worries there. I have bassani o/r x with slp lm1. Anyone know how that sounds with no cats? Thanks in advance
Sonic blue 04 GT~~bolt ons- headers, steeda tri ax, hi tech stage 2 cams coming this winter.
04sonicbgt is offline   Reply With Quote
Old 08-25-2013, 10:29 AM   #14
A Bassani Catless x pipe and SLP lm1s will sound amazing.
Old 08-25-2013, 10:35 AM   #15
04sonicbgt's Avatar
Sweet! Appreciate the quick response
Old 08-25-2013, 01:39 PM   #16
I cut my cats off and ran no cats through flowmasters and my sound barely changed. So I'd say cats don't do **** for sound is you got mufflers. I just cut the cats off and put a straight pipe instead but what get you do do not leave the leak it will cause sensor problems.
RussianGT is offline   Reply With Quote
Old 08-25-2013, 02:21 PM   #17
Had a hard time understanding what you meant, but at one point you did say do do. And i replaced my midpipe entirely and it def changed the sound.
Old 08-25-2013, 04:04 PM   #18
Steve96's Avatar
I think I may have an exhaust leak as well. Car is responding the same as always but can hear a little hiss sound upon hard acceleration, and have noticed more heat than usual coming from the center console/center floor board area.
1996 GT
Old 08-25-2013, 04:11 PM   #19
I replaced the midpipe but idk if its better. If its not there then it must be at the manifold...
Old 08-25-2013, 04:39 PM   #20
Steve96's Avatar
Greenbean: does your center console (near the e-brake area) feel hot to the touch after a longer drive of 40 mins or so? This is where I notice the heat mostly on mine and I have heard a small metal rattle noise at certain rpm levels when I let the clutch out. I hit a high man hole cover and and since then the small hissing, rattle and heat have seemed much worse on mine. Thinking something on the exhaust has come loose near the mid pipe I'm assuming where it connects to the stock manifolds? Just trying to diagnose mine before I get under there, lol.
1996 GT
Old 08-25-2013, 07:09 PM   #21
Mine is up farther in the radio/dash area. Still getting air sputtering sensation. I dont even know any more.
---------- Post added at 06:09 PM ---------- Previous post was at 06:07 PM ----------
If i had a leak at the manifold i found some use bbk shorty headers for $150, does anyone know about the quality/sound of these products.
Old 08-25-2013, 09:24 PM   #22
Steve96's Avatar
I've always heard good things about BBK headers and there product line in general for the most part. My brother had BBK shorties on a 91 notch and they sounded really good. I realize that's a different motor but I would expect that they sound good on a 4.6 as well.
I think I'm gonna take mine in to the local muffler shop and have them look it over and see what they find. Free inspection at my local Midas shop as the guys there seem to be pretty good with all the exhaust change outs I have done. Ill post my findings after I finally get it up there to them (if anyone cares, haha). I'm thinking of ordering a new o/r x pipe if the issue is with the connection, may not be necessary but it gives me a reason to try something else. I've heard decent things about the Pypes x pipe and the UPR x pipe, both are true x pipes vs the chambered style x pipe I have with my current BBK x pipe. Any opinions on the Pypes or UPR x pipes?
1996 GT
Old 08-26-2013, 01:24 PM   #23
I know everyone says dont waste time/money on shortys, but i am not looking for huge hp gains, i just need a factory replacements for my stock manifolds. Are bbk shortys a good brand with quality and what can i expect as far as sound difference.
Old 08-26-2013, 03:23 PM   #24
Damn. No reply. Maybe i needed to be plasti dipping something to get a reply.
Old 08-27-2013, 12:18 AM   #25
Steve96's Avatar
Maybe plasti-dip your entire exhaust and it will take care of the leaks? Jk.
1996 GT
12:34 PM
