Wiring LEDs yo 'Resume' on cruise control - Mustang Evolution
Old 08-09-2013, 02:13 PM   #1
EthanGT03's Avatar
I've been thinking about wiring up some accent leds in my 03 GT and since I never use the resume on the cruise control I figured it would be a clean way to turn them on and off buy wouldn't know how to wire them in to it. I didn't want a random switch that was just hanging around for the leds.
EthanGT03 is offline   Reply With Quote
Old 08-09-2013, 02:51 PM   #2
cliffyk's Avatar
The RESUME switch is a small capacity momentary contact (meaning it woud have to be continuously pressed to keep the LEDs on) unit designed to switch less than 5 mA--in operations it switches a 5 V reference voltage from the speed control servo to ground, through a 2200 Ω resistor.
A typical low-power color LED draws 20 mA, higher power and white LEDs can require up to 100 mA each, obviously a combination of "some" LEDs will be more than that. The bottom line is that neither the RESUME switch or the conductors in the "clock spring" are up to the job...
Old 08-11-2013, 11:56 AM   #3
Iggy's Avatar
Hi Ethan here's where I put my switch hope this helps.
Iggy is offline   Reply With Quote
Old 08-13-2013, 01:14 AM   #4
EthanGT03's Avatar
Haha obviously I'm not much of an electrician but it makes sense what your saying thanks!!
---------- Post added at 02:14 AM ---------- Previous post was at 02:14 AM ----------
So you just drilled a whole through and glued it in or something?
Old 08-13-2013, 05:56 PM   #5
Iggy's Avatar
Yeah drilled small hole then used file made it rectangle so the switch snapped right in. No glue needed
07:43 PM
