Trying to replace vacuum hose - Mustang Evolution
Old 08-11-2013, 06:39 AM   #1
Vmcgrath's Avatar
I had notice on my 98 mustang gt one of my vacuum hose was dry rotted
So I said okay I will just go to the part store, should be an easy fix went to one they said they didn't have it so I went to another part store and they said that they didn't have one either but the could help me find one that work so I said okay bought it for a buck or two and when I put it on crank up up I noticed that when its curved that it get pinched that its getting suck together
Now the hose on the right is what I got from the part store
And the bottom hose is what I'm trying to replace
Anybody know where I can buy to replace my old hose
This is what it look like
Vmcgrath is offline   Reply With Quote
Old 08-11-2013, 06:50 AM   #2
1996mustang's Avatar
You could just run a straight hose like the one u got from the inlet on the plenum to the pcv valve. That plastic line breaks easy and those little elbows are a pain to find. Use about 2 ft of hose should be enough but id measure it just in case. However if u wanna try to find the elvow try under the help section in advanced or autozone or any autoparts see if they have some 90° elbow similar to yours. If not just run the hose straight
Old 08-11-2013, 07:32 AM   #3
Vmcgrath's Avatar
Thanks this information is what I was looking for
Old 12-13-2015, 06:05 PM   #4
Region: Nevada
I had to replace the entire PVC; I took off the same part and was unable to locate one like it. I had to go to a Ford location to get the part. Certainly call around first because it's not a common item!!
maplemargaret is offline   Reply With Quote
Old 12-14-2015, 09:25 AM   #5
fenixignition's Avatar
I haven't found very much for vacuum tubes for this car yet. but ill try to remember to check worldpac when i am at work. they tend to have a lot of OEM parts.
2002 GT 5sp. 16x,xxx miles
Old 12-14-2015, 10:38 AM   #6
infamous281's Avatar
Just get a longer hose so it doesn't bend as much .. or go to the dealership
Sent from my SM-N910T using Mustang Evolution mobile app
09:02 PM
