how long should a fuel pressure gauge take to read full psi? - Mustang Evolution
Old 08-11-2013, 07:12 PM   #1
99NewEdgeGT's Avatar
Region: Arkansas
Hey brothers and sisters, my pony is sick! Last night she would not accelerate past 45mph and started bucking VERY BADLY, then she shut off on me. So I pulled (ROLLED LOL) over and got cylinder 2 misfire and cylinder 5 misfire. She would turn over and then die if I didn't keep my foot on the gas. So I cleared the codes, started her and she got me home ok without shutting off!!
I began to think ok, fuel issue. Went to Auto Zone and rented a fuel pressure tester. When I started my pony it took the gauge about 4-5 min to finally rise to it's highest point of 38 psi.. IS THIS NORMAL? If not, what could be the possible issue here? Any guess is very much appreciated.
99NewEdgeGT is offline   Reply With Quote
Old 08-11-2013, 07:16 PM   #2
Roguestang's Avatar
Doesn't sound normal to me, does your fuel pump prime as soon as you turn the key?
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 08-11-2013, 07:30 PM   #3
Region: Arkansas
Yeah, well at least I think it does. I may have to have the gf turn the key while I listen. But I know at times I have heard it prime. I surely hope its a fuel filter and not a freaking pump.
Old 08-11-2013, 07:44 PM   #4
Roguestang's Avatar
Hopefully it is, but it really isn't that hard to drop the tank and replace it if it came to that. You could also check the voltage to the pump relay, if you can.
Old 08-11-2013, 08:15 PM   #5
Region: Arkansas
Voltage should read 12 volts right? I'm sure that's right, just m.s.
---------- Post added at 09:15 PM ---------- Previous post was at 09:13 PM ----------
But the gauge is suppose to read quicker then 4min though??? Right??
Old 08-11-2013, 08:20 PM   #6
Roguestang's Avatar
I'm not entirely sure of the correct voltage, but it shouldn't take that long. Was it consistently taking that long or did you check it just one time?
Old 08-11-2013, 08:35 PM   #7
Region: Arkansas
Lol just one time, it took soooo long for the gauge to drop down after shutting car off. That I didn't even want to go through the process again. Took over 10min to drop. I eventually just said screw it, got a towel and let gas squirt over it while I unhooked gauge.
Old 08-11-2013, 08:39 PM   #8
Ubnbit's Avatar
http://www.mustang50magazine.com/tec...s/viewall.html
Read the injector section. Might be helpful.
Had u just gotten gas? Done anything different? Have a tune and bought a different grade gas than ur tune?
Old 08-11-2013, 08:51 PM   #9
Region: Arkansas
Originally Posted by Ubnbit View Post
Fuel System DIY Secrets - Tech Information - 5.0 Mustang & Super Fords Magazine
I remember having a race tune on it from bama. But wasnt as aggressive as am says, so I returned it back to stock with very little 93 octane left in the tank. But since then I've been running my stock settings. I think I may have gotten bad gas. I just got some exxon fuel
....drove her and she ran much stronger, but still has hesitation and a idle of 500 rpm.
Old 08-11-2013, 09:00 PM   #10
Region: Arkansas
And when I switched back to stock tune.....that was a month ago btw.
Old 08-11-2013, 09:14 PM   #11
Just a thought here, but could it be a clogged catalytic converter?
My dads truck acted the same way and he had a clogged cat.
Good luck!
Old 08-11-2013, 09:14 PM   #12
Ubnbit's Avatar
That's what it sounds like. If it is only a little moisture, try some gas treatment. See if that helps. Doesn't sound like its anything major. Obviously the fuel pump is working.
Anything else besides just the miss or bogging?
It must not be too full of water or it would be horrible.
Old 08-11-2013, 09:21 PM   #13
Region: Arkansas
Yea a slight miss when accelerating under low rpms. Idle also bounces when in gear. But only when the ac is on. If off, its fine. Ac on in neutral or park its fine. But in drive or reverse ....rpms bounce. She'll take off on her own if brake is not applied good enough.
Old 08-12-2013, 09:39 AM   #14
Region: Arkansas
Good luck!
Mmmm, I deleted my rear catts. Maybe your right, but wouldn't deleting rear catts give front catts better flow? Ill be changing out fuel filter and maf sensor in the next hour. (Fingers crossed).
Old 08-12-2013, 09:46 AM   #15
OK I'm not sure about the better flow :/
Hopefully it's just fuel related and you can be driving again!!
Old 08-12-2013, 09:53 AM   #16
Region: Arkansas
Yea I'm hoping so too. Thanks man. Ill post updates later on today. As most people don't.
Old 08-14-2013, 04:47 PM   #17
Region: Arkansas
Tune up fixed my issue. Thanks guys. Still think its weird how it would miss at times, then not miss, then miss again lol.
Old 08-14-2013, 05:14 PM   #18
Ubnbit's Avatar
If a plug was fouled, it wouldn't be firing on that cylinder. Glad for u brother.
05:36 AM
