Cleaning IAC - Mustang Evolution
Old 08-13-2013, 02:01 PM   #1
twotone01's Avatar
Cleaning IAC
Can I use this carb cleaner to clean my IAC? I had some left over and wanted to know so I don't go buy more cleaning stuff when I could se this. My idle is jumpy some times and won't idle with my AC on. I had the CEL on with a P1507 code but the light went off. Still wont idle. Wanna try to clean the IAC to see if it helps. Thanks!
twotone01 is offline   Reply With Quote
Old 08-13-2013, 02:07 PM   #2
1slosix's Avatar
yes it'll work just fine just don't spray it too much in the plug in for the harness
carving corners like a boss
Old 08-13-2013, 02:08 PM   #3
twotone01's Avatar
Ok thanks, it's also safe to spray inside it right?
Old 08-13-2013, 02:22 PM   #4
twotone01's Avatar
Also what is the box on the IAC hose? I blew through it and it seems like it's restrictive
Old 08-13-2013, 02:37 PM   #5
Mustang936's Avatar
You should be fine cleaning the IAC with carb cleaner.
Here's a good video on it.
Mustang936 is offline   Reply With Quote
Old 08-13-2013, 02:53 PM   #6
twotone01's Avatar
Right on man thanks
Ill give it a try now
It idles completely fine with out the AC on but won't with it on. So hopefully this fixes it
Old 08-13-2013, 03:09 PM   #7
Doe_Rae_mi's Avatar
Don't wanna thread Jack but what exactly do I use to clean my iac?
Old 08-13-2013, 03:26 PM   #8
1shotkllz's Avatar
Carb cleaner does it for me. Basically anything that can clean out any debri or buildup.
1shotkllz is offline   Reply With Quote
Old 08-13-2013, 03:48 PM   #9
1lowGT's Avatar
Maf should work
Old 08-13-2013, 04:07 PM   #10
Doe_Rae_mi's Avatar
Thanks!
Old 08-13-2013, 11:16 PM   #11
twotone01's Avatar
Well my car idles now, before it didn't, but not it just drops really low (like 200-200 rpm) then stabilises. Could it be a vacuum leak? Or is this a sign the iac is bad
Old 08-13-2013, 11:21 PM   #12
slow281
sixpac's Avatar
Region: Nebraska
Is yours a 4.6?
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 08-14-2013, 01:49 AM   #13
twotone01's Avatar
Originally Posted by sixpac View Post
Is yours a 4.6?
Yes it is, 03
Old 08-14-2013, 04:18 AM   #14
Mustang936's Avatar
Hey i had the exact problem with the dropping idle. I got my IAC replaced and still had the problem. If you look under your hood it happens because the Air Conditioning unit will snap on/off causing the idle to dip. Im not sure how i fixed mine but i just disconnected my battery for the PCM to re-learn the idle. I put the air on full blast and drove around a bit, this helped a little bit. After some more driving i think it fixed itself(lucky me). Just Reset your Car and try driving it around so it can learn.
I have also heard that your A/C Pressure switch can cause the compressor to act sporadically. Best of luck to you man, its an annoying problem.
Old 08-14-2013, 10:47 AM   #15
twotone01's Avatar
I will try that as soon as I'm home! I was thinking it might be something with the compressor, like maybe it's starting to seize up or something. Ill let you know when I do it
Old 08-14-2013, 11:29 AM   #16
slow281
sixpac's Avatar
Region: Nebraska
I can send you a good one if you just pay shipping
2001 GT - True Blue
Old 08-14-2013, 11:31 AM   #17
twotone01's Avatar
Ill keep that in mind, i appreciate it. I'm about 30 mid from home so ill check it out today
Old 08-14-2013, 12:35 PM   #18
slow281
sixpac's Avatar
Region: Nebraska
I took it off my 01 thinking it was my problem, ended up being my tps so if you want it it's got 60k miles but works fine.. Ima throw it away if someone don't want it..
2001 GT - True Blue
03:09 PM
