Radiator refill - Mustang Evolution
Old 08-16-2013, 02:51 AM   #1
Polar Bear's Avatar
Region: Asia
Radiator refill
Drained the radiator (97 GT) yesterday just to change fluids. When I refilled it only took about 7 quarts. Does this sound right? Looking at the Haynes manual shows 14. Did I screw such a simple task up?
Steve
Polar Bear is offline   Reply With Quote
Old 08-16-2013, 02:57 AM   #2
Turn the car on with the cap off and start adding more fluid, its gotta get down into the system. Then burp it and rinse/repeat till its got a good fluid level in it.
Old 08-16-2013, 06:36 AM   #3
Polar Bear's Avatar
Region: Asia
Burp it?
Steve
Old 08-16-2013, 07:05 AM   #4
I thought the entire system hold that much, but you will not empty it all in a simple drain, just the amount in the radiator. The coolant in the block and stuff went come out if you just drain the radiator.
I've read most people will drain the radiator, refill, run the engine, drain and refill, run the engine, drain and refill, etc to make sure they get as much fresh coolant throughout the entire system as possible.
Though only way to replace it all was a complete flush
Old 08-16-2013, 07:20 AM   #5
Polar Bear's Avatar
Region: Asia
That seems logical. Just seems hard to get the proper ratio when you can't get everything out.
Steve
Old 08-16-2013, 07:21 AM   #6
1996mustang's Avatar
Fill up the radiator via the hose by the thermo housing. Then fill reservoir. Run the car with the heater on full blast and let it run for 20 min. Drive it around a bit to open the thermostat and if it appears to overheat run the heater on. After cool the car down open and fill up the reservoir. If u wanna burp it you could loosen the temp sensor while runnin to bleed the air out of the system. Many ways to do it
10:18 PM
