Bottom end questions - Mustang Evolution
Old 08-16-2013, 07:04 AM   #1
theweekday's Avatar
So I've been searching for a aftermarket crank shaft for my 00 GT Auto, but I can't find none but forged cobra's.
My question is, do they make them? I'm forging my internals soon and want to get the best out of my 2v. Sorry for my n00bness
theweekday is offline   Reply With Quote
Old 08-16-2013, 07:57 AM   #2
Roguestang's Avatar
Check out summit. I believe they sell a complete lower end rebuild kit both stock and forged versions. The stock crank isn't the weak link in the 2V though, but that all depends on what kind of power you want.
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 08-16-2013, 08:23 AM   #3
theweekday's Avatar
What do you consider the weak link and I'm doing the most N/A before FI
Old 08-16-2013, 08:25 AM   #4
1lowGT's Avatar
Rods and pistons
Old 08-16-2013, 08:26 AM   #5
White03GT's Avatar
Originally Posted by 1lowGT View Post
Rods and pistons
Yup, most definitely
White03GT is offline   Reply With Quote
Old 08-16-2013, 08:29 AM   #6
Roguestang's Avatar
Well most times its the connecting rods. But the better approach would be to figure out your game plan, and build your engine around that. If you bought an eagle forged rotating assembly, that should be good for most people's needs. Or check into a complete short block from the various reputable 4.6 engine builders.
---------- Post added at 10:29 AM ---------- Previous post was at 10:27 AM ----------
Rods and pistons
Haha beat me to it while I was writing my post......
Old 08-16-2013, 08:29 AM   #7
1lowGT's Avatar
Are you building this around a turbo/supercharger? Or building it as bad as you can then adding FI
Old 08-16-2013, 09:25 AM   #8
theweekday's Avatar
Rods and pistons
Well yeah I'm getting those too, when I pull the crank out I'm doing forged pistons. But I mean do they have any that has a good compression ratio
---------- Post added at 10:25 AM ---------- Previous post was at 10:23 AM ----------
Bad as it can be before FI. I already got new roller rockers, springs, lifters and edelbrock jr manifold (all needs to be installed) I haven't looked into heads tho
Old 08-16-2013, 09:34 AM   #9
Roguestang's Avatar
You're gonna want low compression for FI. But you can get any combo of dished pistions from flat top to 18+CC's. I'd stick with the factory 18CC's if your doing FI down the road.
Old 08-16-2013, 09:53 AM   #10
theweekday's Avatar
Do you have a description or write up of differences of piston tops like what your saying?
I never knew what makes them different
Old 08-16-2013, 10:06 AM   #11
Roguestang's Avatar
Not a specific write up, but what is means is the piston top is concave to allow additional room for air in the cumbustion chamber. They measure it in CC's, thus a bigger dish in a piston will equate to a lower compression ratio; generally speaking. If you are a visual person, I'd recommend to google it, and there is a plethora of info on the subject.
Old 08-16-2013, 10:25 AM   #12
theweekday's Avatar
That's what I'm doing now, so low compression for FI, so that's the reason, why when ppl put a FI system on stock GT motors, they only get so much HP right?
Old 08-16-2013, 10:29 AM   #13
Roguestang's Avatar
Well no, that's more with the lack of an extra exhuast and intake valve. The 2V in Stock form doesn't breathe that great, when compared to a 4V
---------- Post added at 12:29 PM ---------- Previous post was at 12:27 PM ----------
Stock 2V (99-04) is around 9 to 1 compresssion ratio. Lower compression is better because it essentially packs more air (and when tuned more fuel and spark) for a better combustion and more power
This link (although from a crap-maro site is useful)
http://www.thirdgen.org/techboard/po...induction.html
Old 08-16-2013, 03:25 PM   #14
WheelStander's Avatar
Just follow the muscle mustang build for 750hp.
Done deal and proven on a dyno.
No brainer.
Induction: Kenne Bell | wHp: 515 Tq: 503 | 1/4 Mile:11.09@123
WheelStander is offline   Reply With Quote
Old 08-16-2013, 04:44 PM   #15
theweekday's Avatar
Is it a sticky?
Old 08-16-2013, 04:46 PM   #16
1lowGT's Avatar
Search
Old 08-16-2013, 04:51 PM   #17
theweekday's Avatar
The app only does so much and the Internet, sucks where I'm at
Old 08-16-2013, 04:53 PM   #18
1lowGT's Avatar
I'll find it and link it here
Old 08-16-2013, 04:54 PM   #19
theweekday's Avatar
Thank you guys a lot for all the input
Old 08-16-2013, 07:29 PM   #20
Rosco's Avatar
Cobra cranks are forged. Might as well pick one up seeing as they're common.
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 08-16-2013, 07:32 PM   #21
White03GT's Avatar
They are a damn good crank as well
Old 08-16-2013, 07:54 PM   #22
Here's how to build a lower end for a blower..
http://www.musclemustangfastfords.co...linder_terror/
Old 09-05-2013, 10:14 AM   #23
Mustang_Madness's Avatar
I have a question about that build. They couldn't have used stock pistons and rods for that so what did they use?? Unless i misread it and it said...
K&N CAI, Cobra 18" Rims, Cobra Brakes, More Mods to come!
Mustang_Madness is offline   Reply With Quote
12:16 PM
