looking into coilovers - Mustang Evolution
Old 08-17-2013, 10:00 AM   #1
Doe_Rae_mi's Avatar
Currently looking at the upr front coilovers, will I need cc plates if I get these? and the ride height will be adjustable correct??
Old 08-17-2013, 10:13 AM   #2
Mile high JDF's Avatar
I haven't researched the UPRs much, but with the MM coil-overs they require aftermarket CC plates because it needs a sturdier strut mount if that what the stock plates can provide. Yes ride height is adjustable.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 08-17-2013, 10:25 AM   #3
Doe_Rae_mi's Avatar
Alrighty thank ya!
Old 08-17-2013, 06:54 PM   #4
You should have CC plates with the stock setup, aftermarket requires it. The UPR setup is a good drag setup. It will go around corners OK. Better than stock anyway and you'll save a ****load of weight. If I keep this 98 and convert to auto the UPR is the route I'm going. And by that I mean it'd be the whole front K/coilover setup. You might as well just do it all at once.
Old 09-20-2013, 09:24 PM   #5
Doe_Rae_mi's Avatar
Well turns out my eibach for some reason are rusted to hell. So I'm most definetly ganna be getting upr coil overs. How hard is it to adjust them?
08:18 PM
