Brake problems now - Mustang Evolution
Old 08-17-2013, 04:18 PM   #1
lx92coupe's Avatar
Brake problems now
Calipers are sticking on the front, and nobody in town has any. It's strange to me that they would both do it at same time. But opened up bleeders and they were very hard to push back
2013 GT Roush Stage1 TVS
lx92coupe is offline   Reply With Quote
Old 08-17-2013, 04:46 PM   #2
wolfstang03's Avatar
What was hard to push back? The pistons?
--WOLFSTANG 03--
wolfstang03 is offline   Reply With Quote
Old 08-17-2013, 05:11 PM   #3
Roguestang's Avatar
Sounds like they might need to be rebuilt. How low were your pads? Sometimes the piston in the caliper can get over extended and is hard to push back in.
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 08-17-2013, 05:13 PM   #4
lx92coupe's Avatar
Yes, the pistons. Put on new pads hoping that pushing pistons back to new location that they would quit sticking. Didn't work, when brakes are applied they stick and keep the brakes on. Will have to order some new calipers Monday
---------- Post added at 06:13 PM ---------- Previous post was at 06:11 PM ----------
The pads were only 1/8" left. Worn out.
Old 08-17-2013, 05:25 PM   #5
Roguestang's Avatar
Well regardless of what caused it, new calipers should fix it. Probably a good time to bleed the lines and put fresh fluid if you haven't already.
Old 08-17-2013, 05:32 PM   #6
lx92coupe's Avatar
The part that sucks is that it got driven 20 miles that way and the rotors got so hot that they are blue. I could have gone and got it with my car trailer
Old 08-17-2013, 05:41 PM   #7
Roguestang's Avatar
Aah yeah, that sucks. Hopefully they aren't warped or cracked at all. Now I would say this is a good time to upgrade but if you're shelling out the bucks for new calipers, it can be tough to get anything else. However, check out American Muscle.com
They have a new product from Power Stop for the 99-04 Mustangs. Its drilled and sloted rotors front and rear, and their own ceramic pads for front and rear for 300.00. That's a really good price, as I paid 125.00 a rotor when I got them (they did throw in the pads). And I can say I love them coupled with Stls braided lines. I got them for my 90' GT as well; it beakes a lot better than stock. Plus they look cool too!
Old 08-17-2013, 06:58 PM   #8
Which car is this for? If its for the New Edge I'd go straight to the Cobra front brake setup, don't even dick around with the GT stuff.
Old 08-17-2013, 07:01 PM   #9
TheBandit's Avatar
I would change the rubber brake lines first before i changed the calipers. I've seen the rubber lines come apart inside and cause this very issue numerous times.
If you do end up changing the calipers be sure you upgrade to the stainless lines or atleast new rubber lines and you will be covered.
Good Luck!!
TheBandit is offline   Reply With Quote
Old 08-17-2013, 07:43 PM   #10
lx92coupe's Avatar
It is the 2000 GT. I still am wondering how both rotors could lock up at same time. I jacked it up and loosened lines to abs module thinking it was blocked somehow. They were still stuck, could not roll wheels. Loosened bleeders, Still stuck. Put on new pads, hit brakes, they stuck again.
I ordered new brake lines for it today, and will be getting new calipers ordered Monday.
Old 08-17-2013, 08:52 PM   #11
Four Eyes's Avatar
Good Luck!!
+10000 check the rubber lines first. What happens is the line deteriorates, and when you apply the breaks, all works as should, but when you release, the rubber flex line will collapse therefore the brakes will stay engaged.
1986 GT with the typical poor boy mods. 3.73s, Hurst short throw, King Cobra Clutch with aluminum quadrant, lowered two inches on Eibach springs, Hopefully adding some heads and a decent intake soon!
Four Eyes is offline   Reply With Quote
Old 08-17-2013, 08:57 PM   #12
They are the same age, see the same use, same pressures, stands to reason they could both fail within a very short time of each other. Maybe one going out took out the other one that was on the way out too? Dunno. You'd be amazed at how much can fail at once in brake lines though. I just got done doing the entire rear brake lines and some fronts too on my Expy and its seemed like every time I fixed one section another section somewhere else blew out. Which I why I just tore it all out...
Old 08-19-2013, 03:44 PM   #13
lx92coupe's Avatar
I have been thinking, and that can be dangerous. Got new 3.73 gears installed and did no correction for speedo. Something about traction control noticed difference and kicked in front brakes. How does that sound for cause of both front calipers sticking same day on low mileage car? And they did it on the trip home from getting those gears
Old 08-19-2013, 05:41 PM   #14
Gears should have 0 to do with it unless those jackasses messed with your ABS sensors during the install.
Old 08-19-2013, 05:44 PM   #15
TheBandit's Avatar
No I wouldnt think so. the traction control works off of the wheels ABS sensors at each corner and goes by the speed of each wheel. So rolling down the road all wheels are going the same speed unless you are doing a burn out... lol
Good Luck and I hope you get it worked out.
Old 08-24-2013, 05:19 PM   #16
lx92coupe's Avatar
I replaced both calipers and brake lines and everything is back to normal. The rotors are ok too. I will always wonder how both calipers locked up at the same time.
Old 08-24-2013, 09:25 PM   #17
Roguestang's Avatar
Well, you may never know, but at least shes back on the road!
09:06 AM
