need help with performance - Mustang Evolution
Old 08-18-2013, 04:32 AM   #1
Anth0nyxGT00's Avatar
I feel my GT needs more power nd acceleration where should i start tho wut bolt ons should i go to 1st input much appreciated
Anth0nyxGT00 is offline   Reply With Quote
Old 08-18-2013, 06:46 AM   #2
1996mustang's Avatar
Im sure scotty will agree. Intake exhaust gears and a tune. That will wake her up
Old 08-18-2013, 07:06 AM   #3
Intake is just for looks, exhaust is for sound. Gears sounds like a good starting point
Old 08-18-2013, 07:10 AM   #4
Intake as in cai and throttle body nd should i go with a cat back system
---------- Post added at 06:10 AM ---------- Previous post was at 06:07 AM ----------
Yea i was thinking gears as well should i try AM tho
Old 08-18-2013, 07:34 AM   #5
Jsansom's Avatar
Yes. Go with am great service and always helpful
Jsansom is offline   Reply With Quote
Old 08-18-2013, 07:38 AM   #6
4.10 right
Old 08-18-2013, 07:38 AM   #7
02GTvert's Avatar
And get forum discount with 50+ posts. Saved me quite a bit.
02GTvert is offline   Reply With Quote
Old 08-18-2013, 07:43 AM   #8
02GTvert's Avatar
4.10 right
Depends on how you want to drive..auto or manual? Daily driven? Strip car? Track car? Going to need a tuner if you want all this done at once and I recommend getting a tuner with a set of gears as the first thing. Then open up exhaust and some suspension work.
Old 08-18-2013, 08:14 AM   #9
Well its definitely not daily driver nd i like to pass ppl a lot i drive kinda fast mostly doing 50 nd 70+ on freeways
---------- Post added at 07:14 AM ---------- Previous post was at 07:14 AM ----------
It's definitely my daily driver*
Old 08-18-2013, 08:19 AM   #10
1lowGT's Avatar
Open the exhaust. Gears. Tune.
Old 08-18-2013, 08:47 AM   #11
02GTvert's Avatar
Well you will suck a lot of gas on the highway with any steeper gear especially if you're going to be on it like you say. But if that's not an issue and you want pep go for it.
Old 08-18-2013, 08:51 AM   #12
1lowGT's Avatar
If you're worried about gas then go with 3.73
Old 08-18-2013, 09:07 AM   #13
White03GT's Avatar
Gear and tuner combo from AM
White03GT is offline   Reply With Quote
Old 08-18-2013, 09:09 AM   #14
Lol gas is no problem nd definitely thanks yu for yur input
---------- Post added at 08:09 AM ---------- Previous post was at 08:08 AM ----------
Not worried about it lol at all
Old 08-18-2013, 09:10 AM   #15
1lowGT's Avatar
If gas is no problem then go with 4.10 for sure! You'll be glad you did.
Old 08-18-2013, 09:12 AM   #16
02GTvert's Avatar
While you're in there get a diff rebuild kit.
Old 08-18-2013, 09:24 AM   #17
That's wut they said on Am to i definitely will
---------- Post added at 08:24 AM ---------- Previous post was at 08:23 AM ----------
Lol thanks i can't wait to see the results
Old 08-18-2013, 09:33 AM   #18
02GTvert's Avatar
Once gears are in you'll need a speedo recal. tool or a tuner to set speedo and odom.. Not necessarily need but they will be off. Just FYI. Like someone stated above a gear and tuner combo from AM would be the way to go if you got the extra $$$ and install is a pretty penny not sure exactly but mine was 700 but I changed axles. $300 to be safe....
Old 08-18-2013, 11:37 AM   #19
MidnightBlueGT's Avatar
Check the bolt on sticky.
gears, tuner, exhaust are the best bolt ons in my opinion, ive done all three recently. With the tuner you can adjust your gear ratio to so the odometer and speedometer wont be inaccurate.
06:54 AM
