clutch problems - Mustang Evolution
Old 08-18-2013, 08:06 PM   #1
stanglover85's Avatar
clutch problems
Went to shift to 5th at 130mph it came out of 4th but basically locked in neutral.... I got slowed down to about 15mph before I was able to get into gear again... Now it's hard to shift... Any ideas?
stanglover85 is offline   Reply With Quote
Old 08-19-2013, 01:02 AM   #2
JimmyMosqueda's Avatar
Clutch cable?
JimmyMosqueda is offline   Reply With Quote
Old 08-19-2013, 05:02 AM   #3
Would that cause the smell of smoked clutch
Old 08-19-2013, 07:18 AM   #4
Your clutch might be out, in that case.
Old 08-19-2013, 08:26 AM   #5
I've had one go out before but nothing like that... Def a weird experience
Old 08-19-2013, 08:31 AM   #6
Could be a variety of things. Clutch cable, clutch itself, malfunctioning shifter assembly. Hopefully someone with more knowledge chimes in.
Old 08-19-2013, 12:13 PM   #7
Yea that's y I posted on here... To see if anyone else has run into this
Old 08-19-2013, 02:04 PM   #8
1996v6stang's Avatar
If ur smelling clutch then i would say either its already out, or something is causing it to stay partially engaged it being partially engaged could also be why u cant get into gears unless at low speed. I wouldnt drive it untill u get to take a look at it.
1996v6stang is offline   Reply With Quote
Old 08-19-2013, 02:59 PM   #9
It only smelled for a minute
Old 08-20-2013, 09:39 AM   #10
I had this same thing happen to me in a 91 except it stuck in 5th and would not come out... sucked. I burned the clutch in 5th just getting it to move but then it popped out and would only go 1-3-5. Turned out to be the pile of **** B&M shifter I had in there.
Old 08-27-2013, 10:26 PM   #11
Really the shifter it's self caused the problem... It's only hard to get into 5th now
11:59 AM
