Cams?? - Mustang Evolution
Old 08-19-2013, 10:27 AM   #1
04__gt's Avatar
Cams??
This is going to get me in some **** and I'm ready for it but what would do I need to do to put cams in my 04
04__gt is offline   Reply With Quote
Old 08-19-2013, 10:36 AM   #2
1996mustang's Avatar
Remove the accessories i.e p/s a/c etc. Remove crank pulley remove valve covers. Remove the timing cover. Undo the chains and then after that remove the bearing caps off the cams and vuola out with the old. However....... what stage u putting in? Do you have adjustable cam gears with the cams. Are yours romeo or windsor cams? A bunch of questions will be asked first on what and y u are changing cams.
Old 08-19-2013, 01:47 PM   #3
Gotta degree them too. So you'll need all the stuff for that.
Old 08-19-2013, 02:06 PM   #4
04__gt's Avatar
I want to get improved cams because some guy in a 03 stopped beside me at the gas station yesterday and his damn car was shaking the concrete loose lol
Old 08-19-2013, 04:33 PM   #5
All that means is he has a loud car. I mean he PROBABLY had a lot of engine work done but you never know.
Old 08-19-2013, 05:15 PM   #6
04__gt's Avatar
Idk man this thing was sitting there just Blum Blum Blum Blum it was nasty
Old 08-19-2013, 05:42 PM   #7
Even really lumpy modular cams usually don't get cray cray like that, was it an Edge? I've heard some SICK pushrods though.
Old 08-19-2013, 05:47 PM   #8
04__gt's Avatar
Yea it was an edge it was sick without looking you would have thought it was a old school monster
Old 08-19-2013, 06:10 PM   #9
White03GT's Avatar
White03GT is offline   Reply With Quote
Old 08-19-2013, 06:31 PM   #10
04__gt's Avatar
Old 08-19-2013, 06:40 PM   #11
04__gt's Avatar
How much would this all run me down you think
Old 08-19-2013, 06:54 PM   #12
Going to be quite a lot. $1k DIY with all the extra stuff you'll need besides the $600 cams... maybe more. If you are getting them installed professionally then prepare thy anus...
This isn't like a pushrod where you buy a $100 used TFS cam off the Corral and install it in an afternoon "dot to dot" and then get another $100 set of new pushrods to match it. Although you really should degree the pushrod cams too. Last one I did was installed "dot to dot" and then verified with a degree wheel and it wound up being spot on. I've had them not be tho.
Old 08-19-2013, 07:10 PM   #13
04__gt's Avatar
Yay
Old 08-19-2013, 07:11 PM   #14
You can do a lot of other **** to your car for the money... if you don't have gears/suspension/exhaust that is stuff to take care of first.
Also you can put a S trim on that car for the same price it would cost to do the cams professionally and you'll go way faster while retaining the stock street manners. Either route requires a tune so that's a wash.
Old 08-19-2013, 07:17 PM   #15
04__gt's Avatar
S trim??
Old 08-19-2013, 07:19 PM   #16
1lowGT's Avatar
Supercharger
Old 08-19-2013, 07:23 PM   #17
04__gt's Avatar
Got ya
Old 08-20-2013, 02:13 PM   #18
Get stage 2 regrinds. They are stock cams that have been regrinded. You can re use cam springs and cam gears with them. Ortiz Performance does them, they are pretty good cams. Only $450
Old 08-20-2013, 03:20 PM   #19
1lowGT's Avatar
I don't know how reliable or good those are but I think I'd rather spend an extra $200 for new comp cams.
Old 08-20-2013, 04:03 PM   #20
They're just fine. MHS used to do regrinds too when they were doing the Recession Buster combos.
Old 08-20-2013, 06:32 PM   #21
Look them up, they are reliable and pretty good cams
02:06 PM
