A/C problems - Mustang Evolution
Old 08-19-2013, 11:04 PM   #1
superboondee's Avatar
Region: Idaho
A/C problems
So I am driving down the interstate today and I turn on my a/c to max ac and the car lost lots of power. It came back after a second but goes back to little power then back fine. And one time there was a hard thump like all the power just stopped like the engine tried to shut off. It shook the car hard and it was fine the next second. Turned the knob to regular ac and the car was better but still felt weak. Shut the ac off and the car was running fine. Is my ac pump going out? I checked for codes and there weren't any.
If you can't beat them, Get a supercharger.
superboondee is offline   Reply With Quote
Old 08-19-2013, 11:30 PM   #2
Rosco's Avatar
Your compressor could have a mechanical fault causing excessive drag, effecting the pulley, and the engine output. Does the car make excessive noise? Does it still blow cold?
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 08-19-2013, 11:40 PM   #3
Region: Idaho
There isn't any noise difference just lots of power loss. It still blows nice and cold.
Old 08-20-2013, 02:47 AM   #4
Compressor is on the way out, I would not use it until you replace it. Happened to my wife's car a few years ago and new compressor fixed it. Luckily, they are easy to get at on these cars, just gotta purge/service up the AC afterwards since the lines will be open to air. Get the compressor from rockauto and then install yourself or find a good AC shop if you are unable. Like I said you'll need to have it serviced either way unless you have the vac/service kit.
08:29 AM
