Could this be the noise in my car? - Mustang Evolution
Old 08-23-2013, 10:40 AM   #1
I've been a kind of chirping in my car. It's not really a squeal tho. I believe I might have gotten it down to this pulley.
I checked the other pulleys and none have play but this one has the slightest punt of play to it.
The belt seems fine the ribs are still in really good shape.
So what is the pulley called? (Hard to search for something when u don't know which it is lol). Could this be the noise? Can I just tighten the bolt or am I gonna have to buy a new one? I heard some ppl for/against belt dressing.
It's the one to the left of the alternator btw
KoolPwny is offline   Reply With Quote
Old 08-23-2013, 10:55 AM   #2
04sonicbgt's Avatar
It is a belt idler pulley I believe, if I were you I'd tighten the bolt, see how it does but if it continues looks like you'll have to buy a new one
Sonic blue 04 GT~~bolt ons- headers, steeda tri ax, hi tech stage 2 cams coming this winter.
04sonicbgt is offline   Reply With Quote
Old 08-23-2013, 11:05 AM   #3
Awesome thanks!
Old 08-23-2013, 11:06 AM   #4
Fader's Avatar
Region: Idaho
#1, NO BELT DRESSING!! If it's making noise, there is a reason for it. Fix it.
#2, Since it's not squealing all the time, I'd suspect it's just the bearing in the pulley. Not likely something you could easily replace or re-pack, so a new pulley should do the trick. The good news is, they are really cheap, and easy to replace.
Fader is offline   Reply With Quote
Old 08-23-2013, 12:28 PM   #5
Doe_Rae_mi's Avatar
My belt chirps when the air is wet. Like when it rains, only last a couple seconds though
Old 08-23-2013, 12:57 PM   #6
Codyclmn9's Avatar
That's not a problem, same thing will happen if you wash use engine degreaser and wash it off. As long as it just last you shouldn't worry about it.
Codyclmn9 is offline   Reply With Quote
Old 08-23-2013, 12:59 PM   #7
Doe_Rae_mi's Avatar
Yea I know that's what I was trying to imply but I guess I failed lmao
Old 08-23-2013, 01:32 PM   #8
Site Sponsor
Sponsor
AMWill's Avatar
Try pouring some water on each pulley individually. If the noise changes or goes away, it's probably the pulley you're addressing at the moment. This is an easy trick that may help!
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
06:56 AM
