Whats your suspension mod list ? - Mustang Evolution
Old 08-24-2013, 03:16 AM   #1
Slow4V's Avatar
Just curious to See how your guys rolling ..
- HP Tokico struts / shocks
- H&R Sportlines
- J&M Uppers / Lowers ( No Quads )
Soon to come ..
- FLSFC
- Tower braces
- Tubular K Member
- Tubular A Arms
- Front Coil overs
Old 08-24-2013, 08:14 AM   #2
Mile high JDF's Avatar
IRS swap
Cut 03 Cobra springs, lowered 2.25" front and 1.75" rear
Tokico D-Spec struts and Bilstein shocks
MM FLSFCs sitting in the garage
Future mods:
MM caster/camber plates
MM coil overs
Steeda bumpsteer kit
Steeda X2 balljoints
MM K-Member
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 08-24-2013, 10:08 AM   #3
Kenny brown: double subframes, matrix bracing, jacking rails, front and rear strut braces, k member brace, c/c plates
Front: Strange adj struts, h&r race springs, steeda bumpsteer, factory swaybar
Rear: sra swap, 31 spline mosers, cobra diff, cobra pinion flange, metco double adj uppers, j&m weight jacker lowers, bmr springs, strange double adj shocks, gt swaybar, quads removed
I'm sure i'm forgetting a few things.
Next up k member, a arms, front coilovers, panhard bar
Old 08-24-2013, 10:09 AM   #4
Horseplay's Avatar
u guys should also post pics along with your list of suspension mods
Low2v
Old 08-24-2013, 10:12 AM   #5
Pics in my garage
Old 08-24-2013, 10:42 AM   #6
Originally Posted by JDF View Post
IRS swap
Future mods:
MM coil overs
MM K-Member
I don't have any pictures of the other stuff.
ID:	125516   Click image for larger version
Old 08-24-2013, 10:52 AM   #7
You need to invest in an irs brace and diff bushings before doing anything else.
Old 08-24-2013, 11:01 AM   #8
I completely forgot about it but I have a Billetflow IRS brace. I definitely want to do the FTBR bushing kit, just haven't had the time or money to do them.
Old 08-24-2013, 11:05 AM   #9
Good deal. I was cutting 1.6 60' on my irs before I started bumping the launch rpm and snapping halfshafts.
Ftbr is definitely the way to go. I chose sra for what I was wanting out of the car for half the price of the ftbr kit.
Old 08-24-2013, 11:10 AM   #10
Yeah I went IRS for the handling characteristics. I do drag race on it but I don't have the stickiest tires and try not get wheel hop when I launch.
Old 08-24-2013, 02:10 PM   #11
CodyNelson's Avatar
Region: West Virgina
KYB gas-a-just shocks/struts
MM c/c plates
Ford C springs w/poly ISOs
J&M uppers and lowers
MM full length subframe connectors
Eibach sways front and rear
Soon to be installed (if I ever get a free day lol):
Strut tower brace
Shock tower brace
Old 08-24-2013, 09:42 PM   #12
Steve96's Avatar
Front: Tokico HP struts
Rear: Koni STR.T shocks
Springs: H&R Super Sports
CC Plates: Maximum Motorsports
Bushings: SR Poly isolators
Ball joints: Steeda
1996 GT
Old 08-25-2013, 12:25 AM   #13
1slosix's Avatar
-SR Performance Springs
-Sensa-tracs
-Poly bushings
-Eibach Strut Tower Brace
-Custom Shock Tower Brace (made from s197 panhard bar)
-upgraded rear sway bar
soon to swap over to Race Land Coilovers and some custom FLSFC
carving corners like a boss
Old 08-25-2013, 07:58 AM   #14
Slow4V's Avatar
So my friend bought a long block from this Motorsport here in town, I had asked him how much he would charge to install subframes to weld them , ( MM ) And he said he would mAke me some that would make MM look like crap, he said it will be way thicker and longer than the MM ones . He has them on his 9sec N/A Mach 1 , he quoted me 200 for parts/labor/paint
Good deal ?
Old 08-25-2013, 09:47 AM   #15
Steve96's Avatar
Doesn't sound like a bad deal to me at all. As long as you trust his work etc.
1996 GT
Old 08-25-2013, 10:58 AM   #16
1slosix's Avatar
As long as the work is solid and they are built straight and true then you're golden...I'd assume he will do a ladder or cross brace design.
Old 08-25-2013, 11:13 AM   #17
Roguestang's Avatar
-Cut stock springs lowered 2" front and 1.5" in rear
-KYB shocks and struts
-BBK strut tower brace
-Bolt-in subframe connectors
Soon to come:
-MM LCA's
-New bushings!!!!!
-Tubular K member and coil overs
As she sits with a set of Goodyear Eagles and she handles on rails. It's alittle rough, but I've never really cared about it. I've kept up with a few stock Porsche's and corvettes in the twistys, so not bad for a live rear axle, and what is done to it, IMO.
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
05:20 AM
