Hard start - Mustang Evolution
Old 08-25-2013, 12:28 PM   #1
Hard start
Another question. I cut off my cat with out thinking couple weeks ago. Cut it before the sensor. Ran it like that for couple days. Than my car start dying when come to a stop but only in drive like a red light or stop sign! Anyways put in a straight pipe instead of converter back in to give the sensor the air and back pressure back but now the dying problem is fixed and everything is back to normal but my car have a hard time starting every time. It starts but I go to crank on it for a second. What could it be?????? Thank you in advance
RussianGT is offline   Reply With Quote
Old 08-25-2013, 12:37 PM   #2
llvllanifest's Avatar
Check out your cam sensor, it might be going out,are you getting any backfire while trying to start it? Also a bad alternator can send bad signals to the cam sensor which would make it seem like a bad sensor even though its good
llvllanifest is offline   Reply With Quote
Old 08-25-2013, 12:43 PM   #3
You probably right it's a sensor. Cuz I got engine check light for sensor but only dealers know the code. Alternator is brand new just replaced it cuz my dumb *** switched battery cables lol live and learn.
Old 08-25-2013, 12:56 PM   #4
FortyBrandon's Avatar
Had something like this happen to our 04gt. It sometimes backfired and it would shut off sometimes when stopped like in reverse or something and was super hard to get started again. Needless to say the mechanic kept telling me I the code read camshaft position sensor that's the problem lol. I told him I said its the alternator. So out of spite I had him change the cam sensor and the car started soon like it did before. So I bought a brand new alternator took it to his shop and I said change it. Half hour later everything is perfect no light or nothing. It was so bad that in park with car running you could switch o headlights and car died.
FortyBrandon is offline   Reply With Quote
Old 08-25-2013, 01:04 PM   #5
Exactly I'd turn ac on and rpm goes down lol I guess il change the sensor. How much is it? My new alternator was 250 lol
Old 08-25-2013, 01:06 PM   #6
Sensor is twenty bucks lol. An I hoped that would've fixed it but nah it just ha to be the 250 dollar altenator. It's not the alternator itself that stops working its something inside that goes wrong and throws off code for cps.
Old 08-25-2013, 01:16 PM   #7
Yes I've been thru this which is why I know , the cam sensor is cheaper but not always the problem . My car would run crappy and hard to start .alternator was my fix . I was upgrading the alternator so it worked out just right , got a 2100 watt system so I needed something beffier to handle the wattage
Old 08-25-2013, 04:33 PM   #8
I wonder if my system is contributing to the problem I got 1000 watt 2 kenwood subs with 1000 watt amp
Old 08-25-2013, 10:22 PM   #9
Your system could be causing your problems. Before I upgraded my alternator and got my yellow top optima battery, all my lights and interior lights would dim really bad when I had my system turned up. Even my car ran rough, so also , have you done the big 3
Old 08-26-2013, 06:27 PM   #10
Big 3???
Old 08-26-2013, 11:19 PM   #11
Yeah the three s's.
Old 08-27-2013, 05:34 AM   #12
Yes sir , that would be your battery ground , positive and your alternator line
04:58 AM
