What is this? - Mustang Evolution
Old 08-26-2013, 09:46 PM   #1
twotone01's Avatar
What is this?
I'm looking at my IAC tube that comes from my intake tube and there is this box in line with the IAC tube, what does it do? I took it out and looked In it ad it looks like foam in there and when I blow through it, it feels restricted.
Thanks
twotone01 is offline   Reply With Quote
Old 08-26-2013, 10:00 PM   #2
emery2483's Avatar
I'm not sure honestly but it kinda looks like a sensor!
emery2483 is offline   Reply With Quote
Old 08-26-2013, 10:01 PM   #3
1slosix's Avatar
i believe it's just an air silencer...i know f150s use something like that as well on theirs.
carving corners like a boss
Old 08-26-2013, 10:05 PM   #4
twotone01's Avatar
Hmm ok, I was wondering if it might have something to do with my idle problem when my AC is on
Old 08-26-2013, 10:15 PM   #5
theweekday's Avatar
Does your idle jump up n down?
theweekday is offline   Reply With Quote
Old 08-26-2013, 10:29 PM   #6
twotone01's Avatar
Yeah it'd does, I cleaned out the IAC and still does it
Old 08-26-2013, 11:08 PM   #7
theweekday's Avatar
Do you have it tuned. When I got my sct it killed that jumping thing yours doing
Old 08-26-2013, 11:12 PM   #8
twotone01's Avatar
No i don't, it's completely stock besides the exhaust
Old 08-26-2013, 11:17 PM   #9
theweekday's Avatar
Or try resetting your car. Just unplug the batt for 30 or so and when you turn your car back on the needles should go all the way back then regular. It helped mines for the time being but it went back to stupid. So a tune only helped to be honest.
Old 08-26-2013, 11:27 PM   #10
twotone01's Avatar
Yeah I've tried that and it was fine for about a day then came back
Old 08-26-2013, 11:47 PM   #11
1slosix's Avatar
go buy some new hose that'll fit between the IAC and intake tube (like $2 in tubing), and swap it out and see if your idle smooths out..maybe that restriction you noticed is a bad thing happening.
Old 08-27-2013, 12:02 AM   #12
twotone01's Avatar
I was thinking about doing that
Ill try it tomorrow and see how it works
Old 08-27-2013, 11:19 AM   #13
twotone01's Avatar
So I stuck some hose where the tube would be and started the car and my idle was at about 1500 the whole time, even when the AC is cycling
08:10 AM
