spark plug gap - Mustang Evolution
Old 08-27-2013, 08:01 PM   #1
spark plug gap
Can the incorrect spark plug gap make the engine misfire? I just replaced my 96 gt plugs and wires with autolight platinums and I assumed they were gapped from the factory. All of the plugs are getting spark so the coils are fine.
Onlyoneromeo is offline   Reply With Quote
Old 08-27-2013, 08:07 PM   #2
Mile high JDF's Avatar
Yes it can. Pull them and check what the gap is at, it should be .054"-.056"
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 08-27-2013, 08:19 PM   #3
Do these plugs normally come pre gapped from the factory?
Old 08-27-2013, 08:22 PM   #4
Roguestang's Avatar
+1
---------- Post added at 10:22 PM ---------- Previous post was at 10:20 PM ----------
Not specificly for a vehicle. I'm only aware of some Bosch Platnum plugs that don't need to he gapped. But best bet is to run Motorcraft or Autolite coppers, and gap them like mentioned above. I should add the ones you got should be fine as long as you gap them too.
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 08-27-2013, 08:53 PM   #5
Fader's Avatar
Region: Idaho
In addition to the plug suggestions received, check your new plug wires for proper connection into the distributor cap. I had a defective plug wire years ago that wasn't connecting solidly in the cap. Caused serious misfire, and burned up the rotor.
Fader is offline   Reply With Quote
Old 08-27-2013, 09:03 PM   #6
Thanx for the tips guys. This is for the 96 gt so theres no dist cap but ill double check everything in case.
Old 08-27-2013, 09:07 PM   #7
Robbiemustang96's Avatar
Nope. Just coil packs.
Robbiemustang96 is offline   Reply With Quote
Old 08-28-2013, 01:42 PM   #8
Ok guys. All seems to be better now. I re gapped the plugs to spec. Thank god because they were all over the place! I read the codes and i had 3 misfires in cyls 1,4 and 8. I cleared them so lets see if they come back.
Old 08-28-2013, 01:50 PM   #9
Old 08-28-2013, 01:51 PM   #10
Roguestang's Avatar
Now you know for next time! Lol
06:56 AM
