AOD Trans - Mustang Evolution
Old 08-29-2013, 07:20 PM   #1
theweekday's Avatar
AOD Trans
Can someone please explain to me what
"fully built" auto transmission is and what it consist of? Im trying to build one in my 00GT, and I already know about the j-mod
theweekday is offline   Reply With Quote
Old 08-29-2013, 07:50 PM   #2
jhherndon's Avatar
My guess is all new clutches, converter, shift kit etc. but what is the j mod? I've heard it mentioned on here and I have an aod as well
2004 Mustang GT
Sonic Blue Auto w/ Full Bolt On's
Quarter Mile - ?? Never Run
jhherndon is offline   Reply With Quote
Old 08-29-2013, 09:23 PM   #3
kickerofdoom's Avatar
You have a 4r70w trans and a j mod is like a shift kit allows quicker shift by making the holes bigger and a built one is like has a new tc and some internal stronger clutches
Old 08-29-2013, 09:33 PM   #4
theweekday's Avatar
So the automatic have clutches? I swear I thought they didn't
Old 08-29-2013, 09:36 PM   #5
BigB227's Avatar
They do, I believe there called band clutches
BigB227 is offline   Reply With Quote
Old 08-29-2013, 09:55 PM   #6
Mile high JDF's Avatar
Automatics have a very different set of clutches compared to a manual transmission.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 08-29-2013, 10:35 PM   #7
theweekday's Avatar
Besides the shift kits that AM sells. Is there anything else that us AOD ppl can do or get to have faster shifts?
Old 08-30-2013, 01:44 AM   #8
Do you have aftermarket cams ? A upgraded valve body.
southernstang00 is offline   Reply With Quote
Old 08-30-2013, 07:22 AM   #9
Semerollin's Avatar
Get a tuner if you don't already have one. You can also use the Lucas Trans Fix. The Lucas will thicken your fluid enough to raise shift pressure. Careful with the Lucas, only use about half a quart. And make damn sure your car is at operating temp and running when you add the Lucas.
Semerollin is offline   Reply With Quote
Old 08-30-2013, 08:26 AM   #10
theweekday's Avatar
I'm working in getting a new valve body and no cams just yet. I heard that the stock converter can't handle cams
---------- Post added at 09:26 AM ---------- Previous post was at 09:25 AM ----------
That stuff actually works? Someone in another thread said the something
Old 08-30-2013, 08:55 AM   #11
BigB227's Avatar
If upgrading to stage 2 cams or bigger then a bigger stall converter is needed. It also requires a dyno tune for both so they go hand in hand
Old 08-30-2013, 08:59 AM   #12
Semerollin's Avatar
I have used it a lot through the years and love it. Some people will say otherwise. The only thing to remember is not to use to much and only add it to a hot/warm trans.
Old 08-30-2013, 09:03 AM   #13
theweekday's Avatar
Well the cams I was gonna get from this performance shop told me the ones they use are custom built and need a better converter so it won't cut off at the light and etc
---------- Post added at 10:03 AM ---------- Previous post was at 10:02 AM ----------
I'll go get some later and let you know it plays out
Old 08-30-2013, 01:08 PM   #14
When I put my cams in I had to get a 2800 stall converter. Its not that it cant handle it but its the stall speed of the stock converter. Those two alone made a difference. Far as the Lucas, I put a bottle in every time I change my fluid because I sub a bottle of Lucas for one bottle of reg trans fluid. it does allow it to shift smoother but I didn't see a big difference nor did I have a issue. The biggest difference you will see is getting a tuner because you can change the shift pressure and points.
Old 08-30-2013, 04:31 PM   #15
theweekday's Avatar
Well I have a tuner I just never played with the other functions cause I'm scared that ill mess something up
Old 08-30-2013, 04:39 PM   #16
I mean I wouldn't go outrageous on it but increase it slowly and you will be okie. Or take it to a near speed shop and see if they will help ya out. When I had my tuned they did all of that , if you have a problem coming about with the trans it doesn't matter if you change things or not it will show.
Old 08-30-2013, 04:48 PM   #17
theweekday's Avatar
You got some detail instructions on how to?
Old 08-30-2013, 05:15 PM   #18
To change the shift points and etc ?
Old 08-30-2013, 05:39 PM   #19
theweekday's Avatar
Yep
Old 08-30-2013, 05:47 PM   #20
Yep
Normally when you start the tuner up and go to the tuning section and you go to change options you do it in there. It will say shift points and followed after that it will say shift firmness or pressure. I don't have my tuner or car right now so I can't go look and give you exact directions. When you want to change it you will increase it by one each time.
Old 08-30-2013, 05:49 PM   #21
theweekday's Avatar
-____- that's it, I feel so stupid. What about the regular tune that's program
Old 08-30-2013, 05:51 PM   #22
Far as the reg turn I'm sure you still can run it and still change the options. I have honestly never used that section because all of my tunes have been custom.
Old 08-30-2013, 05:55 PM   #23
theweekday's Avatar
Yeah mines is too that's why I was scared
Old 08-30-2013, 07:03 PM   #24
Oh ok well try that before doing anything else.
09:38 PM
