IRS exhuast - Mustang Evolution
Old 08-30-2013, 12:11 AM   #1
twotone01's Avatar
IRS exhuast
I've been reading other posts and stuff hearing you can put an IRS exhaust set up on a straight axle. So would I be a me to buy a IRS exhaust set up off AM and bolt it up?
twotone01 is offline   Reply With Quote
Old 08-30-2013, 12:39 AM   #2
Not 100% sure but I think lowflyn used his IRS exhaust when he switched to SRA on his Cobra.
Old 08-30-2013, 01:26 AM   #3
You can use IRS exhaust on a SRA, but not the other way around.
Old 08-30-2013, 02:34 AM   #4
Horseplay's Avatar
wow i didnt know that. so an irs exhaust can just bolt right up then ?
Low2v
Old 08-30-2013, 04:46 AM   #5
Yes.
You have to customize hangers though.
Mine is currently off for suspension work. I'll take a pic or two of the install.
Old 08-30-2013, 06:24 AM   #6
Horseplay's Avatar
Yes.
sweet ! id love to throw that into my gt someday
Low2v
Old 08-30-2013, 07:14 AM   #7
Doe_Rae_mi's Avatar
U can but if you try to put it on a lift the axle will destroy the exhaust,so you would have to remove the exhaust just to get it on a lift
Old 08-30-2013, 07:31 AM   #8
Slow4V's Avatar
That's why drive on lifts where invented
Old 08-30-2013, 07:43 AM   #9
Doe_Rae_mi's Avatar
So ur tellling me if I run an irs on my sra my exhaust would never be in danger
Old 08-30-2013, 08:13 AM   #10
In both cases the exhaust is going to be the exact same height off the ground.
Old 08-30-2013, 11:23 AM   #11
Takes me thirty seconds to drop my tailpipes. You can still jack enough to change a tire.
---------- Post added at 12:23 PM ---------- Previous post was at 12:22 PM ----------
I have never scraped my tailpipes. The mufflers drag on occasion but hell they're 3" off the ground.
Old 08-30-2013, 11:42 AM   #12
Doe_Rae_mi's Avatar
I wasn't talking about the it hitting the ground lol, just the axle raping the pipes, I was always under that impression
Old 08-30-2013, 12:12 PM   #13
Sure, if you jack the body and let the axle droop it will hit the pipes. Being a lowered car I have pieces of wood I drive up on before jacking. That gives me enough space to take the tailpipes off before jacking the car up.
I have never had interference problems between the pipes and rear. If you take a look the swaybar is the lowest point on the rear. My pipes are 1" or so under the swaybar.
Old 08-30-2013, 01:05 PM   #14
Doe_Rae_mi's Avatar
Same here I have to drive up on a piece of wood, I've wanting one but have heard of them being messed up, so apparently if your careful you can get them?? I think I'm about to pull the trigger on one now lol, can I get a pic??
Old 08-30-2013, 03:04 PM   #15
Here's a teaser.
Attachment 126681
Old 08-31-2013, 02:24 AM   #16
theweekday's Avatar
Pleeeeeeeease do a write up on this
theweekday is offline   Reply With Quote
Old 08-31-2013, 07:01 AM   #17
That's the only pic I had on my phone. Just finished swapping shocks and springs. I'll snap a few pics putting the tailpipes back on.
Old 08-31-2013, 08:25 AM   #18
Here ya go. Support mufflers. Install tip of exhaust into hanger. Slide pipe onto muffler. Tighten clamps and done. Two bolts and it slides right off.
Old 08-31-2013, 08:34 AM   #19
Pics didn't attach...try again
Attachment 126787
Attachment 126788
Attachment 126789
Attachment 126790
Old 08-31-2013, 09:04 AM   #20
theweekday's Avatar
What about the the tips? Will they work with the stock?
Old 08-31-2013, 09:13 AM   #21
What do you mean? The tip hangers? They are the same across all mustang models. If you have a v6 they will have to be purchased.
Old 08-31-2013, 09:20 AM   #22
Doe_Rae_mi's Avatar
That's awesome those were some good pics as well, I really want to do this now
Old 08-31-2013, 09:23 AM   #23
If you need more pics let me know. I got the muffler hangers from autozone, any parts store will have them. Bolted it to the lovely mounts ford provided on either side of the driveshaft.
Just have those as temporary, was making sure there were no issues before welding some hangers in place.
Old 08-31-2013, 09:37 AM   #24
theweekday's Avatar
Can you give us some more pics of the how you bolted the hangers for the mufflers?
Old 08-31-2013, 09:51 AM   #25
Here ya go. Just pick up the ubolt hangers. Take the metal strapping and bend it around the mountinf point. Add bolt through top and nut on bottom.
Attachment 126793
Attachment 126794
Old 08-31-2013, 11:49 AM   #26
theweekday's Avatar
How low is your car?
Old 08-31-2013, 12:05 PM   #27
Low...I'm actually raising it some for driveability purposes, that's why I had the exhaust back off. New springs and shocks to raise and give some adjustment on the ride. I just installed BMR 1" drop springs on the back. Going to add an isolator to the H&R Race springs on the front.
Old 08-31-2013, 12:38 PM   #28
theweekday's Avatar
I wanna do that set up but the way my suspension is set up I don't think it would let me
Old 08-31-2013, 12:54 PM   #29
What is your setup? I just raised my rear over 1" and still have zero clearance issues. I can put it any height and show you it won't hit.
Old 08-31-2013, 12:56 PM   #30
02GTvert's Avatar
Is there any advantage over it besides looks?
02GTvert is offline   Reply With Quote
Old 08-31-2013, 12:56 PM   #31
Nice! I like the stance...
Where is a good source to get the isolators? Mine are shot.
Old 08-31-2013, 12:56 PM   #32
theweekday's Avatar
I'll post a pic on how low my car is dropped 2" so to say
Old 08-31-2013, 01:36 PM   #33
No...just looks cool
---------- Post added at 02:36 PM ---------- Previous post was at 02:35 PM ----------
I'm just putting a pair of factory ones on...i have a ton laying around
---------- Post added at 02:36 PM ---------- Previous post was at 02:36 PM ----------
Should be fine then.
Old 09-01-2013, 10:20 AM   #34
If you are super lowered you can have issues with the over axle pipes clearing so in this case the IRS exhaust lets you not worry about that. Other than that, no just looks.
Old 09-01-2013, 10:52 AM   #35
theweekday's Avatar
What about it working with long tubes tho
05:16 AM
