Pwer window help - Mustang Evolution
Old 08-30-2013, 12:01 PM   #1
JB_MUSTANG_V6's Avatar
Pwer window help
My window on the driver side randomly just stopped working. When I press the button it just makes a clicking noise. Is this just the button that went bad or is it the motor? Or is there a fuse? Please help
JB_MUSTANG_V6 is offline   Reply With Quote
Old 08-30-2013, 12:32 PM   #2
JimmyMosqueda's Avatar
Might need a new window regulator.
JimmyMosqueda is offline   Reply With Quote
Old 08-30-2013, 12:35 PM   #3
Semerollin's Avatar
Yep. Just did mine. If you leave it down like 1/8 inch it won't get stuck. Lame I know but it works.
Semerollin is offline   Reply With Quote
Old 08-30-2013, 08:07 PM   #4
02 360R's Avatar
If you bump it pretty good under the handle inside the car, it'll start working again. I just did it today. The 1/8 trick works too, if you can remember every time.
02 360R is offline   Reply With Quote
Old 08-30-2013, 08:22 PM   #5
1lowGT's Avatar
Mine does this occasionally. Bumping the door won't usually work. I click until it drops. But yes leave it rolled down just a hair and it'll always work. I leave mine down but if I forget then it stays up and won't work
Old 08-31-2013, 09:40 PM   #6
XSlashDashX's Avatar
Mine does it when sits out in the sun. But works when it cools off.
Old 09-01-2013, 09:48 AM   #7
1lowGT's Avatar
Wire gets hot and expands and loses connection then cools off and works.
10:34 AM
