Altenator - Mustang Evolution
Old 08-31-2013, 10:06 PM   #1
JB_MUSTANG_V6's Avatar
Altenator
Okay so I was on my way home a little earlier tonight. Got to some blinking lights and decided to punch it. Well gotta good jump and hit second good but then I noticed something. As the pedal was to the floor through 2nd and 3rd the lights started dimming out like they weren't getting enough voltage. I have been having idling issues too so could this be my problem. Not enough voltage output from my altenator?
JB_MUSTANG_V6 is offline   Reply With Quote
Old 08-31-2013, 11:54 PM   #2
That could definitely be the problem. Take your car to your nearest "box" auto parts store and they will test your charging system.
Old 08-31-2013, 11:56 PM   #3
tc x 4's Avatar
Make sure battery in strapped down, could be moving around.
Old 08-31-2013, 11:59 PM   #4
Good point^
And battery cables as well.
Old 09-01-2013, 12:05 AM   #5
tc x 4's Avatar
Originally Posted by straybullitt View Post
Good point^
Ya I had one flip out of the tray, it fried the battery & alternator.
Old 09-01-2013, 12:27 AM   #6
Probably the cable that goes from battery to alternator. Gave me one big headache and left me stranded cause it was loose. If something is wrong with the charging system wouldn't the battery light turn on
Old 09-01-2013, 12:30 AM   #7
Me too. Except it was in a 4wd truck. Lol. It damn near caught the truck on fire...
Old 09-01-2013, 12:43 AM   #8
tc x 4's Avatar
I was 4wheeling too.
Old 09-01-2013, 12:54 AM   #9
Lmao. Yeah, it was fun towing that b tch home. Luckily I didn't live far from where it happened...
Old 09-01-2013, 11:41 AM   #10
So best bet is to take to an autozone and get the alternator tested to see if it's putting out enough amps
Old 09-01-2013, 12:12 PM   #11
Sorry, I missed your post last night BSing with TC.
The light usually won't come on unless the charging system stops working completely. At least that has been my experience with other vehicles...
---------- Post added at 11:12 AM ---------- Previous post was at 11:10 AM ----------
Yes, they should be able to test the charging system.
Old 09-01-2013, 04:36 PM   #12
Well just got my alternator tested and it passed. So I guess I will inspect my cables tomorrow when it's daylight again. Also I noticed the more and more my car is driven the worse it gets with the idling. Meaning from starting to shut off and then starting again to travel to another place. Any suggestions please
Old 09-01-2013, 04:58 PM   #13
Hmmm. It's never easy is it? At least you don't have to buy an expensive alternator. Yes check the cables for corrosion or anything out of the ordinary. Pay close attention to the negative cable. These electrical gremlins can be frustrating but keep faith, you'll get it figured out.
The idle could still be related to your electrical woes, or, maybe not. You should try to figure out the "known" problem first though and go from there.
Old 09-01-2013, 05:07 PM   #14
Yea it was a good and bad result. Good that I don't have to pay $200 for an alternator but now I still don't know what's wrong with it. It's getting very frustrating but I'm determines to figure it out
Old 09-01-2013, 06:02 PM   #15
1996mustang's Avatar
Heres an inside tip. Check the battery light bulb on the dash or the wiring on the circuit board. Its what happened to mine my alty was good and battery yet wasnt charging. Turned out to be the dash light got toast cause of the circuit board wiring. Just my 2¢
Old 09-01-2013, 07:49 PM   #16
Interesting.
The easy way to check for that OP, is to just turn the key to the run position. All of the warning lights should come on.
Old 09-02-2013, 09:20 AM   #17
Slow4V's Avatar
Bad alternator will throw crankshaft/camshaft codes , and will be shutting off your engine..
1. Check battery terminals
2. Go to your local auto parts store & get a battery / Alternator test
For your first diagnostic
---------- Post added at 10:20 AM ---------- Previous post was at 10:16 AM ----------
If your having idling issues , why don't you try to clean out your system?
1. New Spark plugs ( Gap to specs )
2. Clean IAC ( get new gasket )
3. Clean TPS , MAF, ( Ele. Cleaner )
4. Clean Throttle Body ( Intake cleaner )
5. New Fuel Filter
6. Fuel additive & Fill up with 93 oct
7. New Serp. Belt
That's what I'd do ..
Old 09-02-2013, 10:27 AM   #18
Yea I am going to do my spark plugs and fuel filter on Wednesday and hopefully that will fix my problem crossing my fingers.
02:29 PM
