Mushy brakes after SS lines installed - Mustang Evolution
Old 09-01-2013, 12:11 AM   #1
DutchManDann's Avatar
Hey everyone,
So today I installed my new J&M Stainless brake lines and after driving the car they feel slightly mushy.
Its nothing too bad, its not like the pedal goes to the floor before it does anything, but it feels like there is air in the system.
The problem is that my dad and I bled about a pint out of each caliper (starting with the passanger side and then going to drivers side).
so I am sort of at a loss as to what it can be. I checked for leaks too and I dont see any obvious leaks. Anyone have any suggestions?
Thanks,
DMD
DutchManDann is online now   Reply With Quote
Old 09-01-2013, 02:38 AM   #2
1slosix's Avatar
Bleed again...also how are you bleeding them? And when you say passenger to driver side is this going pass front, pass rear, driver rear, driver front? When I installed ss lines a few years ago they did what you described...I bled them 4 times then suddenly my brakes were rock hard and have been since with no issues.
carving corners like a boss
Old 09-02-2013, 11:00 AM   #3
Turns out the pad wasn't seated properly and it was all bent up. Got new pads and everything feels phenomenal now. Thanks for the help!
Roxanne- 1998 Mustang GT Convertible: 5-Speed, 2001 PI 2V swap, o/r h-pipe, Magnaflow catback, MGW shifter,
3.73 gears, Auburn LSD, TA diff cover, MM FLSFCs, Ford Strut Tower Brace, J&M SS Brake Lines, and a lot of visual/restoration work.
04:07 AM
