01 A/C clutch not enaging and overpressured - Mustang Evolution
Old 09-04-2013, 01:26 PM   #1
Balltaatic01's Avatar
The other day my ac started blowing hot air so I tried to add some freon. When I went to add the freon the meter on the can was in the red, between 100 and 150 psi. I'm not very familiar with ac systems so any info would be greatly appreciated.
Balltaatic01 is offline   Reply With Quote
Old 09-04-2013, 01:53 PM   #2
Kevo91's Avatar
Region: Utah
When you had the pressure gauge on did you have your A/C on max ac, full blast?
Kevo91 is offline   Reply With Quote
Old 09-04-2013, 01:53 PM   #3
Yeh
Old 09-04-2013, 02:12 PM   #4
JimmyMosqueda's Avatar
Might have air in the lines.
JimmyMosqueda is offline   Reply With Quote
Old 09-04-2013, 03:13 PM   #5
Pa0729's Avatar
I saw on motortrend that you should never do your own AC work. Even with those bottles that come with the gauge.
Pa0729 is offline   Reply With Quote
Old 09-04-2013, 03:23 PM   #6
Roguestang's Avatar
Take it to a shop and have it done. Pending on the last time it was serviced, you could and proably have a leak. The lines need to be evacuated before they can add the refrigerant, and/or find said leak.
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 09-04-2013, 03:23 PM   #7
2stang's Avatar
possible bad high pressure switch,( easy 1 minute fix). check mini fuse #26
2stang is offline   Reply With Quote
01:59 PM
