Quicker quater mile mods - Mustang Evolution
Old 09-06-2013, 04:33 PM   #1
GreenBean 1809's Avatar
What are some good mods to shed some time off my 1/4 mile at the strip. My biggest issue is hooking up. I was thinking upper and lower control arms and sub frame connector. Anything else? What are sone good brands.
GreenBean 1809 is offline   Reply With Quote
Old 09-06-2013, 04:37 PM   #2
Slow4V's Avatar
Upper CA ( I say YES! ) - UPR is good
Lower CA - UPR is good
Subframes ( Maximum motor-sports )
Drag Radials
Short throw shifter ( Driver Mod )
90/10 Struts
70/30 Shocks
Some good springs would help , really don't need drag springs .. H&Rs are good enough for 11s
You could relocate your battery to help weight transfer..
And if you want to get serious tubular K member , A Arms , Coil overs ..
Old 09-06-2013, 04:38 PM   #3
Venomouz831's Avatar
Driver mod also helps
)02 Gt, Founder of WE2G
Old 09-06-2013, 04:42 PM   #4
This would help.
---------- Post added at 04:42 PM ---------- Previous post was at 04:39 PM ----------
Drag Radials
90/10 Struts
70/30 Shocks
Any idea how much sub frame connectors would cost to be welded in place?
Old 09-06-2013, 04:45 PM   #5
This would help.
Do you get that bullit
Torchred2010gt is offline   Reply With Quote
Old 09-06-2013, 04:47 PM   #6
Slow4V's Avatar
This would help.
100-200
Old 09-06-2013, 04:49 PM   #7
Negative. Guy doesnt have the title, wtf mate. I think its gonna be more fun to keep my car and work on it myself and learn alot with it and then move on with the knowledge to something else, just upgrade things when they break and see how low i can get my 1/4 time down. Going to the track last night and talking to some of the older motorheads made me want to do this. Anyone have input on lighter driveshaft?
Old 09-06-2013, 04:58 PM   #8
And honestly dont want the payments for the next 5 years when mine is almost paid off. Wife wants to look at a bigger house. Wouldn't mind a garage for once! So when i get a car that is worth keeping i can treat it right and garage it.
Old 09-06-2013, 05:00 PM   #9
Slow4V's Avatar
Driveshaft helps too, but IMO id do that more towards the end , unless your a 4V
Old 09-06-2013, 05:05 PM   #10
I figured control arms and connectors this fall so when i get my wheel package in the spring ill be all set.
Old 09-06-2013, 05:36 PM   #11
Very understandable man.i miss my other gt.2002 less than 50k and just paid it off.then some jive turkey ran a red and totaled my baby girl.but I hate payments
Old 09-06-2013, 05:58 PM   #12
Control arms, and better/wider tires are going to help a lot. Will probably cut .5 off your time right there.
Old 09-07-2013, 09:45 AM   #13
Count Dragula's Avatar
Driver mod
---------- Post added at 11:45 AM ---------- Previous post was at 11:45 AM ----------
Let me drive it
2007 Mustang Gt
2.3L Whipple Supercharger
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 09-07-2013, 11:24 AM   #14
Thats what i like to hear! Then brakes, cause then i need to stop, lol. Also thinking short throw shifter.
---------- Post added at 11:24 AM ---------- Previous post was at 11:23 AM ----------
Originally Posted by DSG2003 View Post
Driver mod
Let me drive it
Any time dudeman.
Old 09-07-2013, 11:32 AM   #15
My build list in order for the next year. Any input more than welcome.
Old 09-07-2013, 12:52 PM   #16
I ran a 13.1 with stock heads and cam. No subframe. Drag shocks only. 1.9 60 foot and I had every bolt on besides that.
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 09-07-2013, 12:58 PM   #17
Clink's Avatar
I have a never installed MGW I was gonna put in my '03 Mach 1 but never did due to a missing base shifter cup..still in the box.
PM me if you or anyone else wants it for their 3650, extras included.
Old 09-07-2013, 01:30 PM   #18
Mine is a early 01.
Old 09-09-2013, 05:34 AM   #19
Polar Bear's Avatar
Region: Asia
Underbody coat? You mean the soundproofing?
Steve
Polar Bear is offline   Reply With Quote
Old 09-09-2013, 06:49 AM   #20
No i was thinking of a rust protectant coat, but the more i read about it the less i want it. Seems to lock moisture in so any rust you have will get worse. My car is outside all the time, no garage
Old 09-09-2013, 07:47 AM   #21
White03GT's Avatar
Noone has mentioned gears? Damn.
I have an 03 gt. im doing exhaust, gears, tires, cai, tb, lca, lowering springs, udp, and tuner for now. Gears with suspension and tires will be your best money spent, drastically improve your et and trap. Short throws are amazing as well lol
White03GT is offline   Reply With Quote
Old 09-09-2013, 06:20 PM   #22
Polar Bear's Avatar
Region: Asia
Nice to know. I too am forced to leave my car outside.
Steve
Old 09-10-2013, 08:46 PM   #23
Speed_Mister's Avatar
Region: Arkansas
I'd do 4.10 gears, 275 tires can fit your stock rims, tuner, make your own cold air intake by taking the silencer out in the stock intake and air box out and put a big k&n filter for like a truck on, do the trick flow 75mm throttle body and plenum combo for 265$, o/r x-pipe, with dumps and whatever muffle you want. Make sure the piping is 2.5' and facing downward, move your battery to the trunk, steeds under drive pulley's and you can just replace the bushing with poly bushings instead of the whole control arm lot cheaper and does the same, take your front bumper support off save 30 pounds and gives better weight transfer and it doesn't even hardly do anything anyways, But that's good enough to get you a 13.1 probably in the 1/4.
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 09-10-2013, 08:53 PM   #24
jhherndon's Avatar
What's the front bumper support? Never heard someone mention that before for the weight reduction. And will a 275 really fit a 17x8?
2004 Mustang GT
Sonic Blue Auto w/ Full Bolt On's
Quarter Mile - ?? Never Run
jhherndon is offline   Reply With Quote
Old 09-10-2013, 09:01 PM   #25
Region: Arkansas
It's a big piece of metal and foam pretty much fills in the bumper. (Supports it) I always took mine off in all my mustangs and never had my bumpers fly off even at high speeds at the track or with really hard launches. Just don't stand on it or put lots of weight on it (like stand on it) which you wouldn't do anyways hopefully. Lol but it saves you weight reduction and will lift your front end up more at take off and your rear will go lower creating very little more traction ever weight counts! 100lbs = .1 in 1/4 you can take your rear bumper support out too.. And yes you'll need a newwer tire machine to put 275 tires on 18x8 rims though or else it'll be impossible. I had a buddy try to put them on and couldn't get the beads in.. And gave it to another buddy got them in with no problems with his machine..
---------- Post added at 10:01 PM ---------- Previous post was at 10:00 PM ----------
Also could do egr delete give maybe 3 horsepower plus maybe 5 more pounds and your engine will run cooler. I've done that to my mustangs too.
Full Bolt Ons
370rwhp 470rwtq
Old 09-10-2013, 09:16 PM   #26
jhherndon's Avatar
Wow good to know man and no I don't plan on standing on the bumper lol. Considering your 100 =. 1 puts into perspective that it may be helpful for my big a$$ to lose some pounds lol. Thanks for the help
2004 Mustang GT
Old 09-10-2013, 09:26 PM   #27
03GT88's Avatar
Remove spare tire. Go on diet. Both are free!
03GT88 is offline   Reply With Quote
Old 09-10-2013, 09:30 PM   #28
Region: Arkansas
You can remove front sway bar for way way way better weight transfer! Give you better 60ft which = faster 1/4 times. Ever .1 in 60ft = .2 in 1/4 mile! Lol but seriously it's all in the launch..
Full Bolt Ons
370rwhp 470rwtq
Old 09-10-2013, 10:25 PM   #29
1996v6stang's Avatar
Speed what is your best 1/8 time?
1996v6stang is offline   Reply With Quote
Old 09-10-2013, 11:11 PM   #30
Region: Arkansas
8.16@83
---------- Post added at 12:11 AM ---------- Previous post was at 12:09 AM ----------
That was in my 03 gt 5 speed. I got a new 04 5 speed gt now. I just finished putting all my mods on this new gt. Plus this one has full suspension and 100,000 less miles..
Full Bolt Ons
370rwhp 470rwtq
Old 09-10-2013, 11:27 PM   #31
What do the new 5.0 run in the 1/8
Old 09-10-2013, 11:42 PM   #32
tc x 4's Avatar
Stiffer springs in the rear. When the rear squats, your wasting energy. A front swaybar delete will take 30#+ off the front end for around $100. It's basically a radiator support bracket. The stock bracket is heavy steel because it has to handle the torque from the swaybar.
Old 09-10-2013, 11:58 PM   #33
Region: Arkansas
Not to sure with a decent driver.. I've seen them run 8.4ish and 11's in the 1000 foot.
Full Bolt Ons
370rwhp 470rwtq
Old 09-11-2013, 01:14 AM   #34
How come the upr coilovers for drag racing are only 175 lbs then?
Old 09-11-2013, 01:46 AM   #35
09:47 PM
