Wheel stud - Mustang Evolution
Old 09-06-2013, 07:40 PM   #1
1lowGT's Avatar
Wheel stud
I got a lug that spins and won't come off and back of the rotor that nut spins how can I fix this
Old 09-06-2013, 07:43 PM   #2
Rm360's Avatar
You could try a oversized wheel stud , but I would just get a new hub and replace them all!
Old 09-06-2013, 07:54 PM   #3
1lowGT's Avatar
I can't get the lug off it just spins
Old 09-06-2013, 07:58 PM   #4
Rm360's Avatar
Is there any back and forth movement? Can you push it back and get a vice grip on it? If not , you can use a Dremel tool with a cutoff wheel, cut a notch out of the lug and you should be able to break it with a hammer and chisel, is it the back or front tire?
Old 09-06-2013, 09:16 PM   #5
1lowGT's Avatar
Finally got it off. Had to think for a bit but got it gonna replace the rotors tomorrow.
Old 09-06-2013, 09:20 PM   #6
1slosix's Avatar
dont replace the hub if the stud is bad...just knock it out and pull through a new stud with an impact...super easy on 99-04 models both for the v6's and GT's (takes you all of 15 minutes to do a full hub worth)
carving corners like a boss
Old 09-07-2013, 07:38 AM   #7
Slow4V's Avatar
Are you using hand tools ..
Old 09-07-2013, 11:42 AM   #8
1lowGT's Avatar
Gonna fix it in a bit
Old 09-07-2013, 06:13 PM   #9
Rm360's Avatar
How'd this go for ya?
Old 09-14-2013, 07:30 AM   #10
1lowGT's Avatar
Pretty good, after getting it off anyway. Just took the caliper off knocked the stud out and put a new one in.
11:23 PM
