Main Bearing Issue - Mustang Evolution
Old 09-07-2013, 04:29 PM   #1
Mustang_Madness's Avatar
Main Bearing Issue
I have what i think is a 99 4.6l block that I'm building up to put in the car. I pulled everything and cleaned all i need too, but im having trouble finding the right bearings to put in. I ordered through o reilly's and they gave me bearings without a thrust bearing, so i returned them. then i ordered through Autozone and they gave me the bearings With a thrust bearing, however the tabs are offset and i need centered tabs for the block. I have No clue what bearings i need and am at my wits end trying to find out what bearings and block i actually need and have. Its getting So frustrating. Ive been looking up everything i can about what to get but cant find them. the part number on a bearing that came out is F9ZE-AA. any help is appreciated!
K&N CAI, Cobra 18" Rims, Cobra Brakes, More Mods to come!
Mustang_Madness is offline   Reply With Quote
Old 09-07-2013, 06:07 PM   #2
Im thinking maybe its a truck block which is why i cant find much about it.. Still i need help... So lost..
Old 09-07-2013, 06:22 PM   #3
Mfore33's Avatar
There should be a serial number on the block. Get that and call ford and ask what it is
Old 09-07-2013, 06:32 PM   #4
Where is the serial number? I found a few markings like the R for romeo but theres no plate, or anything i can see.. the engines on a stand so i can check Anywhere...
Old 09-07-2013, 06:53 PM   #5
Mfore33's Avatar
Maybe try and look where the starter goes for a stamp.. You may have to remove the starter also.
---------- Post added at 06:53 PM ---------- Previous post was at 06:50 PM ----------
Or maybe at the rear of the block. It might be a dot matrix kind of type instead of actual numbers. Like this
For a number 3
Old 09-07-2013, 10:44 PM   #6
All I've found are these. I know it was made on 04/18/99 at 9:11. But the rest i have no clue what they mean. Those are all the markings on the engine with visible letters and such. Besides one i couldn't get a picture of. XW7E then below it is 601S or 5 -AA
ID:	127894   Click image for larger version
ID:	127896   Click image for larger version
Old 09-07-2013, 11:37 PM   #7
Mfore33's Avatar
Well I don't know for sure which one is which but maybe a call to ford can clear it all up. The 99 and 2000 blocks are Windsor blocks. All the other 2 valve mustangs are Romeo blocks. Do a search on Romeo vs Windsor and it can tell you all about the differences.
Old 09-08-2013, 03:20 AM   #8
Its a Romeo. Has a nice R planted on the side. Looked it up and its Romeo
Old 09-08-2013, 07:16 AM   #9
Thanks for the help though!
04:04 AM
