Tail lights not working!! - Mustang Evolution
Old 09-07-2013, 08:53 PM   #1
black94stallion's Avatar
I just found out yesterday my tail lights don't work the turn signals work and so do the hazard lights they turn on when the lights are on buy dont brighten up when stopping I also replaced the brake switch
black94stallion is offline   Reply With Quote
Old 09-07-2013, 09:46 PM   #2
1slosix's Avatar
my last 3 mustangs had that issue...turned out to be the two wires that run to the switch in all 3 cases...i ended up just replacing the wires and boom they worked again.
there's a plastic box that the two wires go into that connect to the switch...i got rid of the box because that's where the short was happening. i used female wire ends to connect to the switch no issues. of course i used heat shrink to cover the splices
carving corners like a boss
Old 09-08-2013, 11:28 AM   #3
Awesome thanks man ill do that!!
Old 09-10-2013, 04:26 PM   #4
That did do it I'm getting 12 volts off of it though
09:08 PM
