Bullitt pedals install - Mustang Evolution
Old 09-09-2013, 12:28 PM   #1
XSlashDashX's Avatar
How would one go about taking off the gas pedal? I already installed the dead, clutch, and brake pedal. I took off the 2 bolts from the gas pedal and the clip behind it. But the gas pedal is still hanging from the cable. How would I take it off the cable?
Thanks!
Old 09-09-2013, 01:07 PM   #2
02GTvert's Avatar
Thanks!
Cable slips out.. I think it has a little rubber piece that comes out with it..it's a pain just cuZ it's way up there. Pull it straight up if I remember right easier when one bolt is still in.
02GTvert is offline   Reply With Quote
Old 09-09-2013, 02:12 PM   #3
That's how it looks for now. I still have to put the pin all the way through on the Gas Pedal. I only put it half way through. PITA. Still figuring out how to take the Pedal off.
ID:	128154   Click image for larger version
Old 09-09-2013, 02:39 PM   #4
02GTvert's Avatar
Need a vice..I also sanded the pin down some but not a whole lot. Took probably an hour or so to do, when I figured it was a 10 minute job.
Old 09-09-2013, 04:19 PM   #5
How would I go about using the vice? Do I just use it to hold it in place while I hammer the pin back in?
Old 09-09-2013, 04:54 PM   #6
02GTvert's Avatar
Well what I did since I didn't have a vice was shove the pedal assembly between two desks and c clamp the pin in..lol
08:10 AM
