Steering/braking noise - Mustang Evolution
Old 09-10-2013, 01:10 PM   #1
mustang17's Avatar
I am getting a noise which sounds like it is coming from underneath the car when i brake (the brakes have been changed they are not the issue) and the noise is also coming when i turn my wheel. It is an awful noise it is tough to describe but i can actually here a vibration when i turn the wheel. Mostly the noise happens when the wheel is turned to the right. Recently the noise is getting worse and i can hear it slightly when driving (without moving the wheel). Has anyone had this problem or can you help me with determining what it could be?
HIDs, 20% tint, Mach 1 chin spoiler, Black bullitt wheels, White bumper inserts, Shorty antenna
mustang17 is offline   Reply With Quote
Old 09-10-2013, 01:24 PM   #2
Mfore33's Avatar
My guess would be wheel bearing. Best to replace both at the same time.
Old 09-10-2013, 11:24 PM   #3
Matt5.0's Avatar
Check lug nuts they may be loose, it will give the wheel just a hair of movement.
Matt5.0 is offline   Reply With Quote
Old 09-11-2013, 05:41 AM   #4
mustang17's Avatar
Is it a relatively easy job?
---------- Post added at 07:41 AM ---------- Previous post was at 07:40 AM ----------
I thought that at first so i did check them and they were all good
Old 09-11-2013, 06:22 AM   #5
Mfore33's Avatar
The price for the hub assembly on rockauto.com is 22 to 84 each depending on the one you choose. It's about a 2 hour job. Plenty of how to videos on YouTube. Good luck.
Old 09-12-2013, 05:49 AM   #6
mustang17's Avatar
Ok thanks alot
11:09 PM
