Coolant leak - Mustang Evolution
Old 09-12-2013, 11:19 AM   #1
sally2002's Avatar
Well I found my coolant leak yesterday as I pulled into work. My intake manifold decided to take a crap on me and start pouring coolant out. I'm going to replace it with an OE. What else should I think about replacing while I'm in there? I'm replacing the intake gaskets, and t-stat and gasket.
ID:	128520   Click image for larger version
ID:	128522   Click image for larger version
sally2002 is offline   Reply With Quote
Old 09-12-2013, 11:35 AM   #2
the intake is a common mishap on the new edge isn't it?
Old 09-12-2013, 02:07 PM   #3
sally2002's Avatar
I do believe so
Old 09-12-2013, 02:11 PM   #4
terrible, I wish I had more productive input for this lol
I was just informed that the OE intake has a plasic crossover on the back and you might look into replacing it with an aftermarket like this with the metal crossover? that's just a thought tho
Item Details
Old 09-12-2013, 02:19 PM   #5
sally2002's Avatar
Item Details
That's what mine is its the newer style
Old 09-12-2013, 02:19 PM   #6
Looks like you have it covered.
The only other thing that I can think of is, to clean up the TB and plenum real good while you have it apart. You might even send the fuel injectors out for a good cleaning, depending on the mileage...
Old 09-12-2013, 03:27 PM   #7
sally2002's Avatar
123000 and I just cleaned the TB and plenum not to long ago
Old 09-12-2013, 03:34 PM   #8
You should be good to go...
Old 09-12-2013, 05:25 PM   #9
sally2002's Avatar
Sweet
Old 09-12-2013, 06:37 PM   #10
sally2002's Avatar
Well the intake I got was not OE and doesn't fit. It was a Dorman and everything lined up except one side of the spark plugs. The intake covers a 1/4 of each hole on the passenger side. So now I gotta wait til I get the one I need.
Old 09-12-2013, 06:39 PM   #11
did you get the one I posted?
Old 09-12-2013, 06:44 PM   #12
sally2002's Avatar
Ya I did. Everything works on the drivers side. It's like it was molded wrong or something. Idk
Old 09-12-2013, 06:45 PM   #13
****in A that's gaaaaay
Old 09-12-2013, 06:47 PM   #14
sally2002's Avatar
Ya I no lol it's ok tho it's giving me time to clean the engine up.
Old 09-12-2013, 06:52 PM   #15
H.Doofenshmirtz's Avatar
Region: Australia
I have heard horror story after horror story with these Dorman intakes...by all accounts, go OE/FRPP. Hopefully you're able to get money back or $$ applied to an actual viable part :/
EDIT: As for anything else to do while ur in there, how long since the water pump has been replaced? If its the same 123k then spring another 60 bucks for one from rockauto or steeda
No work and no pony makes Doof a dull boy...
H.Doofenshmirtz is offline   Reply With Quote
Old 09-12-2013, 07:06 PM   #16
sally2002's Avatar
It is original also. I was thinking about doing that also. when I drained all the coolant out of the engine it was kinda darkish and I just changed the coolant maybe a year and a half ago so it had me wondering about the fins deteriorating. Ill look on steeda at the water pumps.
Old 09-12-2013, 07:15 PM   #17
sally2002's Avatar
Also I put Royal Purple coolant additive in it. Should I do it again or not
Old 09-12-2013, 07:18 PM   #18
Region: Australia
Yeah just so i can clarify, steeda stocks the OE waterpump for the cheapest price, rockauto is a tad more, everywhere else seems to think they're solid gold.
I've got a small leak on my intake (bad gasket), or'd a replacement from RA and with 92k on the clock i figured while im in there i may as well do a full coolant flush and replace the water pump. Figured there's no sense in chancing that lol. My latest prob is, tomorrow is 3 months since i got laid off, so extra pony funds arent exactly a high priority at the mo...
Anyways, my .02
Old 09-12-2013, 07:19 PM   #19
Doe_Rae_mi's Avatar
All our intakes go out, just a new edge thing, you gotta replace it I did it about 7 months ago
Old 09-12-2013, 07:24 PM   #20
Region: Australia
Dunno the pros/cons of using RP coolant, but i don't see any reason not too. At least not after flushing the system clean, imho
Old 09-12-2013, 07:29 PM   #21
sally2002's Avatar
Anyways, my .02
I no how you feel about being laid off. I was for a 1 1/2 years. Ill get a water pump coming for sure then.
---------- Post added at 12:29 AM ---------- Previous post was at 12:28 AM ----------
Ya I was told that but didn't believe it. I do now lol.
Old 09-12-2013, 07:34 PM   #22
Doe_Rae_mi's Avatar
Lol yea. My cousin and my 3 friends have had it happen
Old 09-12-2013, 07:36 PM   #23
sally2002's Avatar
I wonder if any of the other vehicles with the 4.6 have this problem?
Old 09-12-2013, 07:37 PM   #24
Doe_Rae_mi's Avatar
I'm not sure, but our intakes are cheaply made, I'm sure they fixed that problem with the 05-09 lol
Old 09-12-2013, 07:46 PM   #25
The last coolant additive I used made my thermostat housing blow up I think haha
Old 09-12-2013, 07:48 PM   #26
sally2002's Avatar
I can't say anything bad about it. I haven't put much money into her. Since I've bought her I've only put both wheel bearings, plugs and boots, and flush of all fluids. Been pretty lucky
---------- Post added at 12:48 AM ---------- Previous post was at 12:48 AM ----------
Was it made of gas or something lol
Old 09-12-2013, 08:35 PM   #27
Wasn't good ish lol
Old 09-13-2013, 06:08 PM   #28
sally2002's Avatar
Well got my Ford Motorsport intake manifold on the way. Also ordered my water pump. Everything will be here Monday. Idk if I can wait that long lol.
Old 09-13-2013, 09:36 PM   #29
Region: Australia
excellent! hopefully you got yer cash back on that dorman POS. keep us posted on the swap and dont forget to properly torque, in sequence
As for your 1.5yrs, man i hope not...thats just too much damn time off lol
Old 09-13-2013, 11:14 PM   #30
sally2002's Avatar
Yes I did and I got my shop manuals handy and they will be used.
Old 09-14-2013, 01:01 AM   #31
slow281
sixpac's Avatar
Region: Nebraska
99-01 intakes go out and every now and then others do.. That's why I bought the PP typhoon intake.. All aluminum.. Maybe not the best performing out there but oh we'll.. And don't buy a dorman.. Ever
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 09-14-2013, 01:26 PM   #32
sally2002's Avatar
I wanted to get that one but funds didn't allow
Old 09-17-2013, 09:18 AM   #33
sally2002's Avatar
Well got my new intake manifold and installed everything back together. Couldn't be more happy to have her back on the road.
Old 09-17-2013, 10:18 AM   #34
Region: Australia
cool bro. How long did it take ya?
Old 09-17-2013, 02:09 PM   #35
sally2002's Avatar
If I had all the parts right then and there it took me 4 hours to do everything. Beings that I had to wait for all my parts I waited 5 days lol. It's a fairly simple job in my eyes.
12:52 PM
