a overheating GT - Mustang Evolution
Old 09-13-2013, 07:15 PM   #1
seth.childers's Avatar
a overheating GT
My 01' GT decided that it wanted to overheat today, and I don't understand how it's doing this unless it could possibly be the water pump. I replaced the thermostat and sending unit couple of days ago. I also noticed that the fan quit working. I am dumb founded... has this happened to any of you?
seth.childers is offline   Reply With Quote
Old 09-13-2013, 08:12 PM   #2
Slow4V's Avatar
Could be a couple things ..
You installed the thermostat wrong
Your head gaskets are no good
You have a air pocket in your system
You didn't connect the sending unit correctly
Fans aren't kicking on when they need to
Old 09-13-2013, 09:02 PM   #3
IMO its not a coincidence that this his happening right after you did the tstat.
Did you check the tstat in boiling water before you installed it? Are you SURE you installed it correctly and not backwards? Are you sure the sending unit is good and properly connected? Did you burp the system when you were done? Did you check for anything crudded up that you might have jostled when you did the install?
Old 09-13-2013, 09:35 PM   #4
I did test the thermostat in boiling water, and it was alright. I'm positive that I installed everything correctly, but I'll check again. The only thing I didn't do was burp the cooling system.. I'll try that and see how that goes.
Old 09-14-2013, 05:39 AM   #5
Slow4V's Avatar
Easy way to do is just open your radiator resv cap and start engine and just let car warm up , until all the air comes out of your cooling system
Old 09-14-2013, 07:58 AM   #6
What is it with ppl not burping their coolant systems after doing maintenance on it? Have fun lifting a head when your car overheats because you couldn't be bothered to take the time to do it right...
Old 09-14-2013, 09:00 AM   #7
I burped the system this morning, and checked everything out making sure I didn't install anything wrong. I drove down the street to see if I fixed the problem... well, it started overheating again. I noticed that my fan wasn't working still, so I unhooked the sending unit and it came back on. So I tried again and drove down the street.. hoping that would help, but it didn't.. it still overheats! I believe I will take it to Ford on Monday if I can't figure it out.
Old 09-14-2013, 09:31 AM   #8
Slow4V's Avatar
Check your oil dipstick and make sure it doesn't have water or coolant on it
Old 09-14-2013, 09:45 AM   #9
I'd recommend you pull the tstat back out and make sure its opening at the correct temp in a pot of boiling water and a digital food thermometer. Also make sure its not installed backwards which happens to the best of us.
06:58 AM
