99 crown vic engine swap - Mustang Evolution
Old 09-14-2013, 08:13 AM   #1
Mustang_Madness's Avatar
So i just found out my engine im putting in my 96 is a 99 crown Vic. I bought it from a guy who said it was from a 98 mustang which is what i had in it before, but the deeper i dug into it, it turned out to be a 99. So my question is can i swap over everything to it or are there any modifications i need to make. it'll be going in my car soon and i want to make sure theres as little problems as can be by the startup date. Thanks!
K&N CAI, Cobra 18" Rims, Cobra Brakes, More Mods to come!
Mustang_Madness is offline   Reply With Quote
Old 09-14-2013, 10:40 AM   #2
1996mustang's Avatar
you will be fine, as long as you make sure u still use your coil packs, since if i remember 99 used coil on plugs. everything is a simple swap over, but just in case make sure you check the flywheel and crank, that will be the change in motor if u have a windsor and if the motor u have now is a romeo. other than that just a straight swap right in.
Old 09-14-2013, 12:40 PM   #3
1lowGT's Avatar
Sorry to get off topic but 96 can you post a picture of your front tires on your wheels i want to get an idea what they look like for my wheels.
Old 09-14-2013, 06:59 PM   #4
It's a Romeo. But for the coil pack i was just gonna use what i had before. What does the 99-04 mustangs have again? I cant think of the name. And thank you!
Old 09-14-2013, 08:22 PM   #5
Mfore33's Avatar
Coil on plug?
Old 09-15-2013, 08:25 PM   #6
Lol right right.. For the life of me i couldn't remember the name.. But i have coil packs so i think I'm good. It was a b)7;& trying to find main bearings that fit but i got them finally. Will i have to tune it again because it's a new engine or no?
Old 09-15-2013, 08:36 PM   #7
No tuning required however would recommend so you can get a little more out of it but when u get more bolt ons
Old 09-15-2013, 08:38 PM   #8
Here you go
03:32 AM
