Catback Install with out distroying originals - Mustang Evolution
Old 09-15-2013, 07:56 AM   #1
MustangGT02's Avatar
Is it possible to take out the stock catback with out destroying it? I want to get the SSS cat back for my Mach but I want to keep the originals so I can put them back on for better value on the car later down the road.
Thanks for the help!
MustangGT02 is offline   Reply With Quote
Old 09-15-2013, 08:00 AM   #2
Doe_Rae_mi's Avatar
Yea it's easy, all you gotta did is unbolt it
Old 09-15-2013, 08:02 AM   #3
Mile high JDF's Avatar
It's possible. You just have to be able to get the rear end low enough to pull out the pipes.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 09-15-2013, 10:18 AM   #4
tonyd01gt's Avatar
+1 on that. the rear section over the rear end is 1 piece.
tonyd01gt is offline   Reply With Quote
Old 09-15-2013, 10:35 AM   #5
Lift the car high enough in the air and you can.
Old 09-15-2013, 11:14 AM   #6
Have you ever actually taken one off? Because the pipes are all welded together and it doesn't just unbolt...
Yeah you have to completely unload the suspension and even then its a PITA.
OP I've always just cut them off in a place with a lot of space to weld back together if I ever wanted to put it back to stock. Any good exhaust shop will be able to put it back in and weld it up or if you or a buddy can weld you can do it in the driveway.
I'm guessing you have an 02 Mustang, not sure what exactly you think you'll be gaining by keeping the stock catback.
Old 09-15-2013, 11:25 AM   #7
+1^ it took me about an hour and a half on BlackedoutBKR 's car and that was with a lift, granted that was my first time taking one off without cutting it.
Old 09-15-2013, 11:25 AM   #8
Doe_Rae_mi's Avatar
Oh I thought they were bolted
Old 09-15-2013, 11:27 AM   #9
That's why the OP was asking about how to get them out. Obviously you'd unbolt them if it was like an aftermarket unit.
Old 09-15-2013, 11:34 AM   #10
It's really not that hard...
Unbolt at h pipe and take the hangers off. Remove.
Old 09-15-2013, 01:50 PM   #11
Doe_Rae_mi's Avatar
That's what I thought
Old 09-15-2013, 07:34 PM   #12
Yes but getting the overaxle pipes out without cutting them is the trick. Not sure what you guys aren't understanding about that. They aren't clamped together like aftermarket catbacks, everything is welded from the flowtubes all the way to the tailpipes. This is why most guys hit the stock catback with a sawzall or a tubing cutter.
Old 09-15-2013, 07:42 PM   #13
Slow4V's Avatar
Where do you buy the sSs exhaust at
Old 09-15-2013, 10:31 PM   #14
I've pulled more off complete than in pieces. I also installed an uncut mach 1 catback on my v6.
Old 09-16-2013, 07:24 AM   #15
I have a 2003 Mach 1 that's 100% original right now.
SSS Adrenaline Cat Back Exhaust System 99-04 GT I've never bought from these guys, are they any good?
Old 09-16-2013, 07:31 AM   #16
I like the fact that they don't sound like every other Flowmaster stang out there.
06:53 AM
