Throw out bearing - Mustang Evolution
Old 09-15-2013, 10:02 AM   #1
1lowGT's Avatar
Throw out bearing
I've have some signs that maybe my tob about to **** out. Few questions. When it's goes bad does it just completely fail or can it be strung out. And can I replace this myself with basic garage tools and jack stands. My car at idle was grinding whining at the stop light and stopped making that noise when I pushed in the clutch. I have no problems getting it in any gear it's all fine besides that noise at the stop light. Normal highway diving I can hear the shifter there make noise but figure that's just because the tranny is right tere without any sound deadening
Old 09-15-2013, 11:30 AM   #2
You can drive it like that for awhile. Transmission obviously has to come completely out to do it so if you think you can do that in your driveway then you should be G2G. Might as well do the clutch too and the pilot bearing should be done any time you have the trans out.
Old 09-15-2013, 12:15 PM   #3
1lowGT's Avatar
Okay well it wasnt making that noise anymore. Put hopefully its not bad. I wanna wait till this summer or winter maybe to do all that. So i can replace more stuff like that while its out already.
Old 09-15-2013, 08:10 PM   #4
I drove for almost a year on a tob that was going bad, but then I barely drive 300-500 miles per month.
Can be done in your drive way, you'll need 4 good Jack stands. If also suggest breaker bars of varying sizes, with various lengths of extensions, and swivel/universal connectors.
Also an extra set of hands would be ideal.
Lastly I'd recommend renting a slide hammer/puller for the pilot bearing.
Old 09-16-2013, 09:11 AM   #5
1lowGT's Avatar
Well hopefully it lasts me till this summer. I Stivers like 6 miles round trip a day so hopefully it's fine.
Old 09-16-2013, 09:16 AM   #6
slow281
sixpac's Avatar
Region: Nebraska
I drive 10k miles on a noisy TOB
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 09-16-2013, 09:22 AM   #7
1lowGT's Avatar
It's not loud or anything but it stops when I push the clutch in
Old 09-16-2013, 09:24 AM   #8
slow281
sixpac's Avatar
Region: Nebraska
Yep just like mine..
2001 GT - True Blue
Old 09-16-2013, 09:30 AM   #9
Slow4V's Avatar
It's like that on almost every mustang I've driven or had
Old 09-16-2013, 09:34 AM   #10
9tee7pony's Avatar
Mine started to chirp shortly after I bought it, then about a year later it completely went and was making either a horrible screeching noise, or a loud grinding noise. It was at that point that I replaced the clutch.
9tee7pony is offline   Reply With Quote
Old 09-16-2013, 09:35 AM   #11
1lowGT's Avatar
I'm gonna wait as long as I can and then upgrade and replace clutch and flywheel.
Old 09-16-2013, 09:38 AM   #12
slow281
sixpac's Avatar
Region: Nebraska
I went with the same fly wheel just resurfaced.. But I upgraded everything else..
2001 GT - True Blue
Old 09-16-2013, 09:44 AM   #13
1lowGT's Avatar
I'm gonna do a lightweight one. And stage 2 clutch.
Old 09-16-2013, 09:51 AM   #14
slow281
sixpac's Avatar
Region: Nebraska
I should have but I woulda had to order it and wait even longer..
2001 GT - True Blue
Old 09-16-2013, 10:28 AM   #15
1lowGT's Avatar
Yeah that always sucks. I'm gonna plan on doing this this summer so I might start buying the parts this winter/spring just so I have everything and don't have to buy it at once.
Old 09-26-2013, 08:02 AM   #16
GHO5T5NIPER's Avatar
Do you have a short throw shifter? Reason I ask is I thought my tob was going bad to until I found out a short shifter doesn't block out transmission noise as well as the stock shifter so its normal to hear transmission whine.
GHO5T5NIPER is offline   Reply With Quote
Old 09-26-2013, 08:07 AM   #17
1lowGT's Avatar
Yes I do. Pro5.0 I think that too.
Old 09-26-2013, 08:11 AM   #18
A transmission noise vs a noise that goes away when you push in the clutch will be different. TOB is a noticeable chirping. Trans noise from the shifter is not like that.
Old 09-26-2013, 08:16 AM   #19
1lowGT's Avatar
I've not had any problems with it noise wise or anything. I'm still thinking about replacing tob pilot clutch and flywheels this summer. If it's not bad by then I'm thinking cams.
Old 09-26-2013, 08:28 AM   #20
You might want to consider that as an option before taking your tranny apart for a tob. I put a cobra bob shifter gasket on my shifter and it helped with the noise a bit. While I had it open I did a full transmission fluid swap with royal purple manual transmission fluid. It shifts a lot smoother and was suppose to help with some noise but I still have a lot of noise coming from the tranny as well. I've heard of people putting dynomat around the inside of the shifter boot and that was suppose to help with noise too but I haven't done that yet. I'm just accepting the noise as normal for now. The only con I have found from the short throw is that annoying extra noise.
Old 09-26-2013, 08:35 AM   #21
The more **** you do to the car the louder it will be. Mine's so noisy when I'm driving that I have to have my phone routed through my speakers to hear anything if I need to make a call on the road (hands free for the phone police). And this is quieter than my 91 was. Lol my ears would ring after I got out of that after more than 20 or 30 minutes of driving haha.
But as far as shifter noise, they all do it except for the MGW which is a lot quieter.
Old 09-26-2013, 08:58 AM   #22
1lowGT's Avatar
Well I'll see where I'm at this summer cuz I'd like to do tranny work and cams. I could do cams myself and then take to a tuner.
12:11 PM
