New engine startup - Mustang Evolution
Old 09-15-2013, 08:27 PM   #1
Mustang_Madness's Avatar
New engine startup
I've heard that when you put a new engine in a car thats been sitting a while, you should expect lots of things to go wrong with it. Any ways i can avoid that when i drop mine in? The cars been sitting for a little over a year and i just got my engine built up to put in. I've drained the gas already but I'm not sure about anything else..thanks!
K&N CAI, Cobra 18" Rims, Cobra Brakes, More Mods to come!
Mustang_Madness is offline   Reply With Quote
Old 09-15-2013, 08:30 PM   #2
MidnightBlueGT's Avatar
Fresh fluids, take your time, research the motor you're installing and swaps in general. Any questions on the way feel free to ask!
Old 09-15-2013, 08:48 PM   #3
Yep. What MB said
You may want to bleed the brakes till fresh fluid comes out. And flush the power steering as well.
Sitting does them no good, but a year isn't too bad...
Old 09-15-2013, 09:29 PM   #4
Roger that! I'll do all of that! Thanks yall! I'll put it in next weekend i think so hopefully all goes well! I'll keep yall updated.
Old 09-15-2013, 09:37 PM   #5
What kind of motor are you dropping in if you don't mind me asking?
Old 09-15-2013, 10:05 PM   #6
It's nothing crazy! Just a 99 4.6 crown Vic engine. I'm building my other one with forged internals so i can go FI later on but I'm thinking of getting a 4v for that.. Not sure yet..
Old 09-15-2013, 10:43 PM   #7
Good luck with build!
Old 09-18-2013, 12:48 PM   #8
DutchManDann's Avatar
When I swapped my engine, I did a couple of things to prevent damage on initial start up.
My engine had been sitting for well over 2 years so I checked the spark plugs, and they needed to be replaced.
While the spark plug was out in each cylinder, I put a little bit of motor oil into each cylinder to theoretically get everything lubed a bit because its been sitting so long.
obviously changed oil.
I would seriously recommend taking the fuel injectors and cleaning them. My engine barely started/ran like crap for ~10 miles because all the injectors were clogged up with bad fuel.
I let mine warm up before i did any serious revving. Although revving the engine is actually good for it, youll clear out any moisture/crap in the engine. Like my injectors, they cleared out as I was accelerating up to about 4k
i had most of my radiator stuff out while i did the swap so I cleaned all the coolant related parts out too.
if theres anything else youre considering, do it while the engine is out. I painted my whole engine bay while mine was out. good time to do motor mounts, steering rack, or A/C related stuff too.
DutchManDann is offline   Reply With Quote
Old 09-18-2013, 01:02 PM   #9
I don't have heat or AC so dont need to worry about that, however i Do want to clean out my injectors! Can i do it myself or do i need someone else to do it? Also, I've drained my fuel tank already and i have new oil ready to go. Same with coolant. What did you clean out regarding coolant? Thanks man. I appreciate the input.
Old 09-18-2013, 02:50 PM   #10
I just had a set of injectors cleaned by mrinjector.us.
$16. each. He cleans them using the ASNU process (ultrasonic) and installs new pintle caps, O rings, and, most importantly, new fuel filters in the injectors. Something that the fuel injector cleaner/Seafoam guys are overlooking...
He flow tests them and sends you the before and after results.
He even paints them.
Old 09-18-2013, 03:55 PM   #11
Hmmmmm..... I'd rather do it myself but i suppose not.. Oh well! Thanks
« EGR Delete | Coil »
04:12 PM
