Spark plugs? Idle issue as well - Mustang Evolution
Old 09-16-2013, 08:04 PM   #1
XSlashDashX's Avatar
Before I install my SR Intake, the idle was i guess okay. It would drop down to 500 and go back up to 1000 Rpms when I push the clutch in. I watch a video about the idle control valve. And it could be it. But the part is like 130 bucks for motorcraft oem. Dura last is 40 bucks.
Now since I install cold intake, the idle seems a bit ruff and when I'm going 60 or any speed. I can feel like something is jerking me back every 10 -20 seconds.
1998 GT.
Old 09-16-2013, 09:07 PM   #2
1lowGT's Avatar
Any misfires?
Old 09-16-2013, 10:40 PM   #3
Haven't checked but feels like it. I've disconnected the Battery for a bit so the cold intake wouldn't cause a check engine light.
Old 09-16-2013, 11:17 PM   #4
irishn8's Avatar
Seems like you have a COP going bad, thats what mine did. At this point u might see the CEL come one for a second or two or maybe not yet. If you see ur CEL come one when it jerks id say thats it and get a COP and the hex driver and keep it in the car for when it goes bad. I always keep one in the trunk anyway.
---------- Post added at 10:17 PM ---------- Previous post was at 10:16 PM ----------
I just notice u said ur cel is on all the time anyway. Well go ahead and get a COP just in case and when it goes bad you'll know coz ur running on 7 cylinders.
Old 09-16-2013, 11:23 PM   #5
irishn8's Avatar
Now i just noticed you have a 98? So no COPs. Then spark plug, wire, or coil pack. Did you ever replace that coil pack?
Anyway, def sounds like a misfire, thats usually easier to diagnose when its constant i.e. running on 7 cylinders.
Old 09-17-2013, 01:21 AM   #6
Is the screaming demon coil pack any good? Ask because they come in 2 pair. MSD comes with only 1 each.
Plan to stick with oem motorcraft plugs and get ford racing wires.
Old 09-17-2013, 06:34 AM   #7
irishn8's Avatar
Mmmm id go with MSD, i never heard anything bad about them.
Old 09-17-2013, 07:53 AM   #8
Lola never eh? They're the Fram of the ignition world. Their ignition boxes are especially bad. You wouldnt catch me with a MSD product near my car. I go with Crane if I go aftermarket.
Old 09-17-2013, 12:38 PM   #9
So MSD is the FRAM version?
Old 09-17-2013, 09:57 PM   #10
irishn8's Avatar
Well...theres a first. Idk man, im no aftermarket expert. All i know is i never herd bad about it before now, only good. I know its not top of the line but ive been using it and have had no problems.
Old 09-17-2013, 10:27 PM   #11
Well, considering screaming demon since it saves money and comes with 2.
Old 09-17-2013, 10:44 PM   #12
Slow4V's Avatar
Ford OEM coil packs > Everything
Old 09-18-2013, 02:11 AM   #13
SonicBlueRider's Avatar
^^ +1
SonicBlueRider is offline   Reply With Quote
Old 09-18-2013, 05:26 AM   #14
Like Fram, MSD goes off a ****load of marketing and name recognition. The products themselves are meh quality wise and you can get a better product for the same price if you know what's what. As far as Fram, their orange cans of death are aptly named but if you drop $12 on their better ones the quality is decent. And you will have wasted $6 since you can get a Wix filter for half that but I digress...
Don't. You won't save any money because they'll **** out on you well before the Motorcraft ones. Also, OEM Ford units are $45 each on Rockauto. Also you can just change the boot and spring of your current COPs and see what that does vs replacing them. $30 gets you enough boots/springs/etc... to do all 8.
Look around, you'll find plenty of negative MSD stuff on forums. Their ignition boxes in particular are ****. Internals wise they look like they are put together by a 6 yr old with a hot glue gun.
Agreed, if you replace coil packs, ONLY buy OEM Ford units.
10:16 AM
