Is my engine a Remeo or Windsor!? - Mustang Evolution
Old 09-17-2013, 05:53 PM   #1
Ok guys I'm stumped and have read all sorts of stuff on other forms and google.
I have a 2000 GT but replaced the motor but need to find the year so I order the correct Hydraulic tensioner.
I believe it have 11 bolts but cannot get far enough back to see if there are any bolts behind the valve cover.
The oil fill is on the pass side
I have pink injectors (the same ones that came in the engine)
These numbers came off a white sticker on the valve cover.
2C2E-6582-EB
3G 837 AA
Patrickandberry is offline   Reply With Quote
Old 09-17-2013, 06:09 PM   #2
1996mustang's Avatar
Romeo has 11. Windsor has 13/14
---------- Post added at 08:09 PM ---------- Previous post was at 08:06 PM ----------
Better way to know is look at the 8th digit of your vin. X is windsor and w is romeo
Old 09-17-2013, 06:11 PM   #3
He said the motor was replaced and doesn't know which one it was replaced with.
Old 09-17-2013, 06:19 PM   #4
Ok count the passenger side. If u see 11 its romeo any more is windsor
Old 09-17-2013, 06:39 PM   #5
Lol. Googled those numbers and this thread was the first one to show up.
You need to find the serial number. The Romeo will have XW7E in it and the Windsor will have F75E.
My money is on it being a Romeo...
Old 09-17-2013, 06:57 PM   #6
They say the s/n is on the back of the block, it will take an act of congress to find that
Old 09-17-2013, 07:02 PM   #7
It's never easy is it...
Old 09-18-2013, 02:27 PM   #8
Mustang_Madness's Avatar
Dont Romeos have an R stamped on the block? Mine does...
K&N CAI, Cobra 18" Rims, Cobra Brakes, More Mods to come!
Mustang_Madness is offline   Reply With Quote
Old 09-18-2013, 04:48 PM   #9
I believe so im 99% sure it is a romeo if its stamped r
Old 09-24-2013, 06:03 PM   #10
Well I removed the valve covers both sides had 11 bolts each which would make it a remeo
12:40 PM
