pulley problem? - Mustang Evolution
Old 09-19-2013, 11:33 AM   #1
Horseplay's Avatar
pulley problem?
why does this make noise when i turn on the ac ?? is it the pulley or what is it ? need some help
Low2v
Old 09-19-2013, 11:51 AM   #2
Horseplay's Avatar
anyone?
Low2v
Old 09-19-2013, 12:44 PM   #3
You have 4 pulleys in the pic. Can you be a little more specific?
Old 09-19-2013, 02:06 PM   #4
Horseplay's Avatar
sorry i thought the pulley that was the center of the pic was obvious.
this is the one that makes noises
Low2v
Old 09-19-2013, 02:24 PM   #5
02GTvert's Avatar
That's the tensioner..probably not the one.
02GTvert is offline   Reply With Quote
Old 09-19-2013, 03:04 PM   #6
Horseplay's Avatar
can it be lose or something. i know this is whats making the noise
Low2v
Old 09-19-2013, 03:09 PM   #7
02GTvert's Avatar
Well if you turn on the ac and it does it..it's probably ac pulley or the compressor..undo the belt and spin the tensioner pulley see if it spins freely. Or ticks as you spin it. My guess it's not the tensioner if it does it with ac on. Someone else may know more.
Old 09-19-2013, 03:18 PM   #8
bigmac3's Avatar
The tensioner pulley basically freewheels when the AC is off. When you turn it on, you put a load on it. Sounds to me like you may have a bad tensioner pulley bearing. Easy to change. If you hand turn it without the belt on, you can feel a bad bearing. If it's smooth, it's probably your AC clutch.
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Old 09-19-2013, 03:44 PM   #9
Horseplay's Avatar
ok thanks alot
for the info guys
Low2v
01:28 PM
