No power to starter solenoid - Mustang Evolution
Old 09-19-2013, 07:07 PM   #1
Jesshawk35's Avatar
My 99 gt won't crank. I'm stumped.. It's got power up to the clutch switch but then at the relay in the distribution box there is no power going to the switch. I'm thinking maybe it's the pats system, maybe the key needs reprogrammed. But the theft light come on when I turn the key on but then it goes off and stays off. Anyone have any suggestions? It's not a bad power or ground because I can jump power to the solenoid wire and it cranks. Thanks for any input.
Jesshawk35 is offline   Reply With Quote
Old 09-20-2013, 10:49 AM   #2
1996mustang's Avatar
Maybe its a blown fuse? Fuse is what sends power to the relay to the starter...... could be a fusible link as well. Start simple it cranks when power is direct meaning somewhere in the circuit to the starting system you have no power
09:58 AM
