Quadrent and Firewall adjuster?.. - Mustang Evolution
Old 09-19-2013, 09:03 PM   #1
slow281
sixpac's Avatar
Region: Nebraska
Is there and hint and tricks as to how I adjust my quadrant and firewall correctly.. As if I unscrew it more will it be tighter or losser?? Help!
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 09-20-2013, 06:02 AM   #2
Unscrewing (out towards you) brings the pedal engagement up, screwing it in moves it further towards the floor. You could also just do it and get in the car and see how it feels lol. Every firewall adjuster I've ever used has notches so you can count how many "clicks" in or out you've gone and keep track of where you are at. Can't speak to any possible ebay special you might have but my Steeda unit does as do all the others I've played with.
Old 09-20-2013, 07:29 AM   #3
slow281
sixpac's Avatar
Region: Nebraska
Well I have the UPR one and a steeda quadrent.. But it's all the way in and the engagement is all the way at the top of the pedal...... -_-
2001 GT - True Blue
Old 09-20-2013, 07:35 AM   #4
There are likely 2 or 3 hooks on the quadrant. Yoga yourself under the dash and have a gander at it and see what's up.
Old 09-20-2013, 07:46 AM   #5
slow281
sixpac's Avatar
Region: Nebraska
we just put it in its the single hook.. If I bought the triple hook one would that help?
2001 GT - True Blue
Old 09-20-2013, 10:21 AM   #6
First make sure you have the cable routed right. Also did you get an OEM replacement cable or the MM OEM style one or something else?
Old 09-20-2013, 10:39 AM   #7
slow281
sixpac's Avatar
Region: Nebraska
Oem
Replacement.. It just seams pretty tight..
2001 GT - True Blue
Old 09-20-2013, 11:35 AM   #8
I had issues with my single hook and went to a triple. Much better
Old 09-20-2013, 02:30 PM   #9
slow281
sixpac's Avatar
Region: Nebraska
What one did you get !?
2001 GT - True Blue
Old 09-20-2013, 07:46 PM   #10
Free one from a friend, those are the best. I believe it's a steeda.
My setup is spec 3+, stock flywheel, stock cable, fiore microclick and steeda 3 hook quadrant. Just tap the pedal and slam the next gear.
Teamed with the wot box and mgw I have perfected wot shifts, even in cars without a wot box.
Old 09-20-2013, 07:54 PM   #11
slow281
sixpac's Avatar
Region: Nebraska
Free one from a friend, those are the best. I believe it's a steeda. My setup is spec 3+, stock flywheel, stock cable, fiore microclick and steeda 3 hook quadrant. Just tap the pedal and slam the next gear. Teamed with the wot box and mgw I have perfected wot shifts, even in cars without a wot box.
Probably have to get one of those.. I just see so many diffrent ones..
2001 GT - True Blue
10:49 AM
