AND WHATS THIS PART!!! - Mustang Evolution
Old 09-20-2013, 02:06 PM   #1
going threw my engine bay I noticed this piece has a wire that's about to break off, its exposed and only hanging on by a couple pieces of wire.. there is one on the passenger and drivers side.. any idea what part it is
Mustangman705 is offline   Reply With Quote
Old 09-20-2013, 04:49 PM   #2
If it is an all black wire that you are referring to, then it is a ground wire.
I'd fix that...
Why is the photo, in this thread, of an engine compartment that looks, probably, like most of the cars that many of us are driving everyday, and in your previous thread, the engine compartment, on THAT car, looked like someone had just gotten it ready to serve dinner on??!?!!?
Old 09-20-2013, 04:53 PM   #3
1996mustang's Avatar
You are referring to the noise filters.
Old 09-20-2013, 05:01 PM   #4
There noise filters... how so its a square piece that bolts on, has a wire that plugs into an adapter.. are we thinking of the same part
---------- Post added at 05:01 PM ---------- Previous post was at 05:00 PM ----------
steam clean
Old 09-20-2013, 05:08 PM   #5
steam clean
They're ground wires...
LMAO at steam clean
That is a completely different car my friend...
Fat Pony?
Old 09-20-2013, 05:15 PM   #6
ground wire for what.. so I can ask for a new one.. will the new ground wire come with that block on the end and the clip on the other
Old 09-20-2013, 05:19 PM   #7
I dont know...
If there is enough left on both ends just splice it back together and solder it and you'll be back in business...
Old 09-20-2013, 06:57 PM   #8
White03GT's Avatar
Agree!
White03GT is offline   Reply With Quote
Old 09-20-2013, 08:02 PM   #9
H.Doofenshmirtz's Avatar
Region: Australia
LMAO at steam clean
Fat Pony?
LMFAO thanks for pointing it out Did a side-by-side of those two, and this car in this thread is frikkin BLACK. What didja do, "steam clean" into a new color? (EDIT: Nice job switching out your CAI between pics too...)
VERY FP-esque lol
No work and no pony makes Doof a dull boy...
H.Doofenshmirtz is offline   Reply With Quote
Old 09-20-2013, 08:21 PM   #10
cliffyk's Avatar
They are air gap capacitors, used to shunt the high frequency spikes generated by the COPs to ground and give the PCM and other on-board electronics a break...
Old 09-20-2013, 08:40 PM   #11
Interesting.
I never really noticed them before this thread.
They do look like something more than your typical ground...
Learn something everyday...
Old 09-20-2013, 09:02 PM   #12
Thanks man, no idea what that means but thanks... any idea if that cable snaps would it cause harm to my engine...
Old 09-20-2013, 09:05 PM   #13
Fix the wire MM...
Old 09-20-2013, 09:58 PM   #14
I googled air gap capacitors for a 2000 mustang gt and doesn't seem to have any info on them at all.. are you sure that's what they are called... I would like to replace it but cant find any info on them or where to order it
---------- Post added at 09:58 PM ---------- Previous post was at 09:53 PM ----------
I found Those are radio ignition interference capacitors, they're a pair of air gap capacitors intended to reduce noise in the radio from your ignition system.
so basically its not guna make much of a difference if I replace it or just forget it, seems to not really do anything important... is my assumption correct
Old 09-20-2013, 10:09 PM   #15
Just repair the wire. If you need the connector, go to the nearest auto parts store. They'll be able to figure out which one that you need.
---------- Post added at 09:09 PM ---------- Previous post was at 09:04 PM ----------
Yes. They also protect the electronics on the car.
For the last time MM, FIX THE WIRE...
Old 09-20-2013, 10:20 PM   #16
I will go to napa tmrw and get a new one, I don't have a soldering gun ..
Old 09-20-2013, 10:37 PM   #17
If you have a Harbor Freight nearby, soldering guns are pretty cheap.
Some will argue that a properly crimped wire connector is as good or better than a solder connection. Especially if you can't solder good...
Pick up some shrink tubing while your there and you should be all set.
Old 09-20-2013, 10:54 PM   #18
how about the good old twist the wires together and use electrical tape method... hahah jk ill price the part out and if its cheap ill just replace it... plan to keep the car forever so no point in taking short cuts
Old 09-20-2013, 10:57 PM   #19
Haha... Hey, it'll work in a pinch!
06:26 PM
