alignment issues - Mustang Evolution
Old 09-22-2013, 10:44 PM   #1
03gteddy's Avatar
alignment issues
Okay so I recently installed my H&R super sport spring without any iso's along with the maximum motorsports caster camber plates but when I took the cart to get it align they said that they could not do better than a negative 2% camber. Does anyone else have his problem.?
03gteddy is offline   Reply With Quote
Old 09-22-2013, 10:47 PM   #2
1slosix's Avatar
no with C&C plates they should be able to get you to 0 camber is you so wish..although i will say i have mine set for almost 2 degrees off so i can get better traction in corners.
carving corners like a boss
Old 09-22-2013, 11:56 PM   #3
03gteddy's Avatar
The alignment shop showed me and the plate was maxed out and it had the 2 degree and I'm only concerned for the tire ware
Old 09-23-2013, 10:01 AM   #4
cliffyk's Avatar
Do you have a photo of the CC plates as installed in your car?
The Maximum Motorsports CC plates can be assembled with the bearing plates oriented in two ways. One provides a "positive" camber range, the other a "negative" range. It may be necessary to reverse the bearing plates to get the adjustment range you want.
This is from the MM installation instructions:
-2° camber will cause excessive wear on the tires' inner tread; it will also make the car handle much better...
Old 09-23-2013, 10:20 AM   #5
Venomouz831's Avatar
Take it to another shop see what they say
)02 Gt, Founder of WE2G
Old 09-23-2013, 10:34 AM   #6
03gteddy's Avatar
Originally Posted by cliffyk View Post
Do you have a photo of the CC plates as installed in your car? The Maximum Motorsports CC plates can be assembled with the bearing plates oriented in two ways. One provides a "positive" camber range, the other a "negative" range. It may be necessary to reverse the bearing plates to get the adjustment range you want. This is from the MM installation instructions: -2° camber will cause excessive wear on the tires' inner tread; it will also make the car handle much better...
I don't have a pic at the moment but my plates are like the bottom picture and the slots are maxed out and the plate hits at the end
Old 09-23-2013, 10:46 AM   #7
cliffyk's Avatar
The bearing plates need to be reversed so as to be as shown in the top "positive" position diagram. The "negative" position allows a range of most negative camber adjustment; this is only needed when people want to max out the camber for autocross or other racing.
This seems to be a fairly common issue, over the years I have reversed a them on a couple cars and pointed the issue out to a half dozen or so people on the forums--IDK if MM is shipping them out in the "negative" position or if they are just ending up being installed that way?
Old 09-23-2013, 01:18 PM   #8
03gteddy's Avatar
I had then installed I never really opened the box but I will take a picture when I get home to make sure
09:03 PM
